Hi,
Tried to use the beta version of Audirvana with Chord Mojo ASIO driver for Windows 10 and it crashes on startup. Memory goes to very high values on task manager and the Audirvana doesn’t even come up showing. Eventually it complains about SQLdatabase corruption, and suggests to delete the file. I tried to do that but the issue persists.
Regards,
Thanks for the feedback
Can you get some crash log by:
- launch the Event Viewer application
- Open Windows logs, then Application
- Search for an entry from Windows Error Reporting, with id 1001 (crash)
The details of the entry should be about AudirvanaPlus.exe
It may also mention a file where the crash log details are stored.
Can you then send me by PM this log entry text, and the attached file (if exists)?
This will be very helpful to pinpoint where the crash has occured.
Is it also crashing when the Chord Mojo is not connected? If yes, I’ll try installing its ASIO driver to reproduce the issue
Hi Damien,
The logs created by the crash are in a zip file and it seems that I cannot attach here this kind of file. I don’t know if it’s supposed or not (first time I’m on this forum), or how do you want me to send these to you. Is there another mail address ? Or you are looking for a particular filename. Also I can tell that Audirvana crashes as soon as I launch it with chord mojo connected and on. Otherwise, without chord mojo connected I already listened Tidal streaming without any problems. If that’s important I’m using windows 10, with latest upgrades, and I have 16 GB RAM on a Lenovo X1 Carbon.
All the best
Thanks,
Just sent you a PM
Hello,
Audirvana crashes here with my T+A DAC 8 DSD. If I switch to Asio Audirvana crashes immediatly. The T+A isn’t connected in Audirvana. The next Start I get the message about a basd database.
Best regards
woflt
Hello here are the logs:
Fehlerbucket , Typ 0
Ereignisname: AppHangTransient
Antwort: Nicht verfügbar
CAB-Datei-ID: 0
Problemsignatur:
P1: AudirvanaPlus.exe
P2: 1.0.0.0
P3: 5b1fd826
P4: unknown
P5: unknown
P6: unknown
P7: unknown
P8:
P9:
P10:
Angefügte Dateien:
\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3F95.tmp.WERInternalMetadata.xml
\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3FC5.tmp.xml
\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3FC4.tmp.csv
\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3FE4.tmp.txt
Diese Dateien befinden sich möglicherweise hier:
Analysesymbol:
Es wird erneut nach einer Lösung gesucht: 0
Berichts-ID: c65e56e9-63bb-4060-a14a-e490d5ac9f47
Berichtstatus: 2049
Bucket mit Hash:
CAB-Datei-Guid: 0
I use Chord Mojo as well. All my listening is with Tidal.
It works well with no upsampling
With Master files (MQA) I hear a clicking sound 10-15 sec into playback that does not go away.
I can upsample to 2X but anything higher will sound full of high pitch noise, clicking sound and basically sound not music. This happens 10-15 sec into playback.
In terms of SQ, I need to check it against my Mac min with Audirvana when I get back home (on vacation now) but it is a lot better than Tidal app.
Hello
MQA seems fixed.
Upsample to DSD still not good (both drivers)
Upsample to Power of 2 still not good (both drivers)
Debug info for DSD below:
Upsampling:
SoX to DSD64 with filter type A 4th order
Phase = 73
Library Settings:
Sync list: 0 folders
Library database path: C:\Users\MHadjdai\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Active streaming services
TIDAL: ON
Local Audio Engine:WASAPI
Preferred device: Digital Output (Chord Async USB 44.1kHz-768kHz) Model UID:Digital Output (Chord Async USB 44.1kHz-768kHz) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{9ce89491-e97f-41d4-801d-d1be2327781b}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Active Sample Rate: 384kHz
Digital Output (Chord Async USB 44.1kHz-768kHz) Manufacturer:
Physical (analog) volume control: No
Virtual (digital) volume control: No
Simple stereo device: No
2 ch Integer PCM 24bit little endian 352.8kHz
2 ch Integer PCM 24bit little endian 384kHz
2 ch Integer PCM 24bit little endian 705.6kHz
2 ch Integer PCM 24bit little endian 768kHz
Device #0: Speakers / Headphones (Realtek Audio) Manufacturer: Model UID: Speakers / Headphones (Realtek Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{c985204c-83e3-4509-8633-314b499e20d8}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Digital Output (Chord Async USB 44.1kHz-768kHz) Manufacturer: Model UID: Digital Output (Chord Async USB 44.1kHz-768kHz) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{9ce89491-e97f-41d4-801d-d1be2327781b}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Debug info for power of 2 below:
Upsampling:
Phase = 73
Library Settings:
TIDAL: ON
Sorry MQA playback is not fixed. There is a clicking sound using both drivers.
Damien
Do I need any other info from me?
Update
MQA playback issue is now fixed on latest release.
I still had issues with DSD upsample when Mojo was directly connected to computer but was able to upsample to DSD 64 when I had Schiit Eitr between computer and Mojo.
Will test soon with a difernt dell laptop which is more powerful than the current one.
Posted in wrong thread. Please remove.
This is the debugging of my configuration with the Chord Mojo connected in ASIO mode.
Upsampling:
Phase = 73
For track: ON
Library Settings:
AUTO: C: \ Users \ Salv_G \ Downloads \ HighResAudio.com
Library database path: C: \ Users \ Salv_G \ AppData \ Local \ Audirvana \ AudirvanaPlus \ AudirvanaPlusDatabaseV2.sqlite
Qobuz: ON
TIDAL: ON
Local Audio Engine: ASIO 2 driver version 2
Preferred device: ASIO Chord 1.05 Model UID: ASIO Chord 1.05 UID: ASIO Chord 1.05
Device: 2ch 32bits Integer, 8 bytes per 192kHz frame
Active Sample Rate: 192kHz
ASIO Chord 1.05 Manufacturer:
Preferred stereo channels L: 0 R: 1
Number of active channels: 2, in 1 stream (s)
Channel # 0: Stream 0 channel 0
Channel # 1: Stream 0 channel 1
Local devices found: 1
Device # 0: ASIO Chord 1.05 Manufacturer: Model UID: ASIO Chord 1.05 UID: ASIO Chord 1.05
UPnP devices found: 0
