Hi! i have a problem with reproduction in mi new DAC (Marantz HD DAC1). I configurate all like the instructions says and got no sound. Says “can’t open an audio file”. Im trying to reproduce in windows 64 bits. Need some help.
Hello @Arturo_Avila,
Says: “DSD not compatible”
Audirvana 3.5.12
Sync list: 0 folders
Library database path: C:\Users\medpu\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
TIDAL: Connected as FREE
Max. memory for audio buffers: 13584MB
Local Audio Engine:WASAPI
Interfaz de sonido digital (2- Marantz USB Audio)
Model UID:Interfaz de sonido digital (2- Marantz USB Audio)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{e8fd06d7-7d95-4bdc-b428-d4326f94ad52}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Active Sample Rate: 192kHz
Marantz DAC (2- Marantz USB Audio) Manufacturer:
Model UID:Marantz DAC (2- Marantz USB Audio) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{e8fd06d7-7d95-4bdc-b428-d4326f94ad52}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
7 available sample rates up to 352800Hz
Simple stereo device: No
2 ch Integer PCM 24bit little endian 352.8kHz
Local devices found : 3
Device #0: Altavoces (GSX 1200 Pro Main Audio) Manufacturer: Model UID: Altavoces (GSX 1200 Pro Main Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{36a162f1-8fd2-4e3c-a979-a8afb91f1705}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Marantz DAC (2- Marantz USB Audio) Manufacturer: Model UID: Marantz DAC (2- Marantz USB Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{e8fd06d7-7d95-4bdc-b428-d4326f94ad52}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #2: Headset Earphone (GSX 1200 Pro Communication Audio) Manufacturer: Model UID: Headset Earphone (GSX 1200 Pro Communication Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{97ce63ac-5610-4485-883f-30ec446081ca}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
UPnP devices found : 1
Device #0Dormitorio UID: uuid:a191eea3-2256-43b5-e5ab-0553793b5980 Location: http://192.168.0.11:8091/a191eea3-2256-43b5-e5ab-0553793b5980.xml
Are you trying to play a DSD file?
Im trying to play Tidal Music from Audirvana. Not reproduces a single song.
And my DAC its compatible with DSD, also in my first install a was able to listeng with no problem. I change the DAC to my MacBOOk and Imac and this problem appears.
Disable the upsampling and try again.
Already disable and nothing.
Problem solve!!! THANKS
One last question…, why DSD says it is not supported? My DAC features says it is compatible.
If your DAC is compatible with DSD over PCM, you can set the native DSD read method to “DSD over PCM 1.0” in the device section of the audio settings page.
If your DAC has a volume control, you may need to ensure it is set at 100% during DSD playback to prevent its USB interface from damaging the DSD signal.
Thank you for all mate.
