I have an Apple TV that I can target with Airplay in iTunes on my Mac/Mojave.
In Output Audio Settings, Audirvana does not propose to use Airplay.
Try to select AirPlay device in macOS settings… you should then be able to select it from Audirvana
Can you paste the debug info here?
I do not see where I can select Airplay device in macOS settings.
… where you can set the volume of internal speakers …
Thank you very much.
I will try it.
I have tried it and it works.
