Audirvana doesn’t recognize the DSD compatibility of my Topping d50s DAC, I installed the driver and everything but the problem still, hope there is someone that could help me
Did you select dsd over pcm 1.0 or 1.1 (allow dsd256) in dac prefs
I cannot select anything because in the dac configuration it appears that it does not have compatibility
As Damien posted many times, can you post the debug info… maybe there is something there to see…
Audirvana 3.5.37
SoX with 2x upsampling
Sync list: 0 folders
Library database path: C:\Users\seba_\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 2414MB
Local Audio Engine:WASAPI
Altavoces (TOPPING USB DAC)
Model UID:Altavoces (TOPPING USB DAC)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{efd5966a-acbd-411b-b9d7-603d24ff8056}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Altavoces (TOPPING USB DAC) Manufacturer:
Model UID:Altavoces (TOPPING USB DAC) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{efd5966a-acbd-411b-b9d7-603d24ff8056}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Simple stereo device: No
Device #0: Altavoces (Realtek High Definition Audio) Manufacturer: Model UID: Altavoces (Realtek High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{9f042cf2-053d-4c26-8e07-ca7e2ba34eea}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Altavoces (TOPPING USB DAC) Manufacturer: Model UID: Altavoces (TOPPING USB DAC) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{efd5966a-acbd-411b-b9d7-603d24ff8056}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
First i’ll set upsampling at OFF… second i’m on a Mac
but i know there is 2 drivers for Windows usually … Wasapi and ASIO…
did you try the other?
Resolved! i updated windows and then tried to do the first thing you told me and now i can listen DSD Files, thank you!
Sorry to hijack this. I’m in the same boat here. Just got a Topping D50s, connected to my MacPro 2013 running Mojave, and just installed the trial Audirvana. I’m trying to play DSF and DFF files, which produce music but the Topping displays says it’s PCM and the Audirvana Audio Output selection says DSD not supported.
Have you tried to set DoP 1.0 or 1.1?
Hi there, in my case im using windows 10 and I need to change from wasapi to asio otherwise i cant reproude DSD and also select DSD over PCM
Thanks.
@bitracer - that option isn’t open/ changeable on either the desktop app or the android app.
@sebas_dro - yeah, I’m getting that from my reading too. I was just going to use an old mac mini to do the job, but I may have to install bootcamp on it for windows.
Cheers
By the way, is there a way to change the default view of the app please? I’ve organized my albums into alphabetical folders for clarity, but the app doesn’t seem to have an option to show a ‘folder view’.
You need to (re)install the drivers.
The default view when you open Audirvana is the where you’ve been in the app before closing it. About the folder view, we had a lot of request about it and we take it in consideration for a future update of Audirvana.
