I used an Apple Time Capsule for many years for network connectivity, but it recently broke down. So I switched to my ISPs gateway/router, which is a Technicolor Xtream. Now my two players will unfortunately only connect with Audirvana over WiFi, which would be OK if they both used the 5GHz protocol. My Yamaha NP-S303 network player does not, and occasionally produces choppy sound over WiFi.
Why won’t the players connect to Audirvana over cable? The router sees the players, they are there all right. And the players indicate that they are connected as well, and will indeed play internet content. I feel like I have tried everything. I repeat, using the Time Capsule all I had to do was plug the cables in. I thought the router was faulty somehow, but today a replacement arrived and there is no improvement. Is the problem with Audirvāna Studio using this particular router - what am I missing? Would port forwarding help? I’m on the latest MacOS. Appreciate any help!
