I am using Audirvana (licensed) the last 3 weeks without any problems. Since upgrade to 3.5.37 Audirvana freezes while loading the first track - the playlist is visible but it semms that Audirvanan is not able to load the track - any idea? Thanks for your thoughts
My system: Win 10 with KEF LSX
Same problem here… after a few minutes Audirvana collapses.
My System: Windows 10 - Cambridge CXU
Shrinked my favorite list. Now it works, let‘s see…
Hello @step_hu,
I have reinstalled Audirvana and now it runs (sometimes…)
In certain circumstances Audirvana will only play the first song of an album and then stops playing and then it does not run anymore…
Thanks for your help.
I send you now the debug infos:
Audirvana 3.5.38
AUTO: G:\0 iBasso
Library database path: C:\Users\step_hu\Audirvana\AudirvanaPlusDatabaseV2.sqlite
Preferred device: Stephans KEF Model UID:KEF Stephans KEF UID:uuid:5f9ec1b3-ed59-1900-4530-841715024768
UPnP device at http://192.168.1.138:8080/description.xml
Stephans KEF Manufacturer:KEF
Volume control: No
http-wavetunes::audio/x-ms-wma:*
http-get::audio/3gpp2:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/x-aiff:
http-get::audio/aiff:
http-get::audio/vorbis:
http-get::audio/x-vorbis:
http-get::audio/x-vorbis+ogg:
http-get::audio/ogg:
http-get::audio/x-ogg:
http-get::audio/m4a:
http-get::audio/x-m4a:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
CurrentTransportStatus: ERROR_OCCURRED
NrTracks: 1
MediaDuration: 0:03:27
CurrentURI: http://192.168.1.114:49152/audirvana/audio_1_7.wav
CurrentURIMetadata:
dc:titleConqueror</dc:title>
dc:creatorAURORA</dc:creator>
upnp:artistAURORA</upnp:artist>
upnp:genrePop</upnp:genre>
upnp:albumArtURIhttp://192.168.1.114:49152/audirvana/artwork_1_8.jpg</upnp:albumArtURI>
upnp:albumAll My Demons Greeting Me As A Friend (Deluxe)</upnp:album>
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions X_DLNA_GetBytePositionInfo InstanceID in A_ARG_TYPE_InstanceID TrackSize out X_DLNA_CurrentTrackSize RelByte out X_DLNA_RelativeBytePosition AbsByte out X_DLNA_AbsoluteBytePosition LastChange string TransportState string STOPPED PLAYING PAUSED_PLAYBACK TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED PlaybackStorageMedium string NETWORK RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string PossibleRecordStorageMedia string CurrentPlayMode string NORMAL NORMAL SHUFFLE REPEAT_ONE REPEAT_ALL TransportPlaySpeed string 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NumberOfTracks ui4 0 1 CurrentTrack ui4 0 1 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string A_ARG_TYPE_SeekMode string TRACK_NR REL_TIME X_DLNA_REL_BYTE A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4 X_DLNA_RelativeBytePosition string X_DLNA_AbsoluteBytePosition string X_DLNA_CurrentTrackSize stringCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 DMR-1.51 MS_DigitalMediaDeviceClass_DMR_V001 MediaDevices MicrochipCE2CY920_0xBD VEN_14E7&DEV_0001&REV_01 Multimedia.DMR QPlay:2.1 SeekOnPaused urn:schemas-upnp-org:device:MediaRenderer:1 Stephans KEF KEF http://www.kef.com/ LSX SP3994 94 http://www.kef.com/ 841715024768 uuid:5f9ec1b3-ed59-1900-4530-841715024768 123810928305 image/jpeg 48 48 24 /BCO_device_sm_icon.jpg image/jpeg 120 120 24 /BCO_device_lrg_icon.jpg image/png 48 48 24 /BCO_device_sm_icon.png image/png 120 120 24 /BCO_device_lrg_icon.png urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/desc.xml /RenderingControl/ctrl /RenderingControl/evt urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/desc.xml /ConnectionManager/ctrl /ConnectionManager/evt urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/desc.xml /AVTransport/ctrl /AVTransport/evt urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /QPlay/desc.xml /QPlay/ctrl http://192.168.1.138UPnP devices found : 3
Device #0Stephans KEF UID: uuid:5f9ec1b3-ed59-1900-4530-841715024768 Location: http://192.168.1.138:8080/description.xml
Device #1Swisscom tv box 1 UID: uuid:bc323f0a-12ba-11ea-882b-4c09d4d80976 Location: http://192.168.1.108:56866/aw
Device #2Swisscom tv box 3 UID: uuid:d8bc4912-a1e0-11ea-9644-f08620833534 Location: http://192.168.1.135:59229/aw
Max. memory for audio buffers: 12426MB
Local Audio Engine:ASIO 0 driver version 0
Local devices found : 0
Hello @step_hu,
I can see that you are playing Conqueror but it’s seems to not have other track after it, do you see other trakcs in your playqueue when you click here?
Hi Damien
Yes, I have 17 songs in the playqueue …
Just to be sure, are you using the latest firmware from KEF? It should be 4.1
When you try with Bubble UPnP, do you have the same issue?
Sorry, I don’t know what you mean with Bubble UPnP…
But in the meantime I restarted all components, connect my KEF’s to Spotify an com back to Audirvana ans now it works, weird…
Here a new Debugging Info when it runs, maybe it helps… - to you see any differences?
Audirvana 3.5.38
AUTO: G:\0 iBasso
Volume control: No
DLNA 1.5: Yes
NrTracks: 1
MediaDuration: 0:03:42
CurrentURI: http://192.168.1.114:49152/audirvana/audio_1_26.wav
CurrentURIMetadata:
dc:titleWarrior</dc:title>
upnp:albumArtURIhttp://192.168.1.114:49152/audirvana/artwork_1_27.jpg</upnp:albumArtURI>
upnp:originalTrackNumber8</upnp:originalTrackNumber>
nextURI: http://192.168.1.114:49152/audirvana/audio_0_27.wav
Murder Song (5, 4, 3, 2, 1)
AURORA
AURORA
Pop
http://192.168.1.114:49152/audirvana/artwork_0_28.jpg
9
object.item.audioItem.musicTrack
PlayMedium: NETWORK
Device #0Swisscom tv box 3 UID: uuid:d8bc4912-a1e0-11ea-9644-f08620833534 Location: http://192.168.1.135:59229/aw
Device #2Stephans KEF UID: uuid:5f9ec1b3-ed59-1900-4530-841715024768 Location: http://192.168.1.138:8080/description.xml
Max. memory for audio buffers: 13168MB
Local Audio Engine:ASIO -1 driver version -1
I see that your next file is ready to be played in your LSX. If it happen again, try to restart your LSX
