Hi,
below the log file, in several lines you can see “http://192.168.49.1:60000” . What is this address?
http://192.168.2.14:49152 it’s my pc
The log file is too long, I’m sending you just a part regarding 01/06. (or let me know how to send you the whole file)
2021-01-06 19:37:42,667 [25] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 19:37:42,674 [30] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 19:37:42,677 [10] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 19:37:42,872 [9] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 19:37:42,874 [7] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 19:37:42,875 [4] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 19:37:42,879 [31] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 19:41:44,738 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_0_16.wav on instance 0
2021-01-06 19:42:48,001 [26] DEBUG Audirvana.App - Error obtaining device description from http://192.168.2.10:8888/capability – error = -204
2021-01-06 19:42:48,005 [15] DEBUG Audirvana.App - Error obtaining device description from http://192.168.2.10:8888/capability – error = -204
2021-01-06 19:43:44,632 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_0_17.wav on instance 0
2021-01-06 19:43:50,020 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_1_19.wav on instance 0
2021-01-06 19:44:14,037 [6] DEBUG Audirvana.App - UPnP: Error 401 resetting NextAVTransportURI when stopping
2021-01-06 19:44:46,479 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_1_21.wav on instance 0
2021-01-06 19:45:00,187 [4] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 19:45:00,187 [23] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 19:45:00,240 [25] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 19:45:00,242 [7] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 19:45:00,349 [10] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 19:45:00,349 [9] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 19:45:00,352 [30] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 19:45:00,359 [13] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 19:45:00,542 [31] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 19:45:00,542 [28] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 19:45:00,570 [32] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 19:45:00,572 [33] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 19:46:58,580 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_1_22.wav on instance 0
2021-01-06 19:47:07,456 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_0_24.wav on instance 0
2021-01-06 19:47:10,396 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_0_25.wav on instance 0
2021-01-06 19:47:10,733 [37] DEBUG Audirvana.App - UPnP: error restarting playback when switching to next track
2021-01-06 19:47:11,496 [28] DEBUG Audirvana.App - UPnP: Error 401 resetting NextAVTransportURI when stopping
2021-01-06 19:47:20,730 [1] DEBUG Audirvana.App - Error 501 starting UPnP playback
2021-01-06 19:47:30,378 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_1_28.wav on instance 0
2021-01-06 19:48:20,294 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_1_30.wav on instance 0
2021-01-06 19:48:22,187 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_1_31.wav on instance 0
2021-01-06 19:52:42,640 [11] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 19:52:42,642 [6] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 19:52:42,646 [12] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 19:52:42,654 [33] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 19:52:42,834 [26] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 19:52:42,836 [15] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 19:52:42,842 [29] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 19:52:42,845 [30] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 19:52:43,042 [9] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 19:52:43,052 [7] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 19:52:43,052 [10] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 19:52:43,054 [4] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 19:55:05,419 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_0_33.wav on instance 0
2021-01-06 19:57:30,076 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_0_34.wav on instance 0
2021-01-06 19:57:31,737 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_1_36.wav on instance 0
2021-01-06 19:57:38,629 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_1_37.wav on instance 0
2021-01-06 19:57:39,597 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_0_39.wav on instance 0
2021-01-06 19:57:50,579 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_0_40.wav on instance 0
2021-01-06 19:57:51,481 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_1_42.wav on instance 0
2021-01-06 19:59:28,140 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_1_43.wav on instance 0
2021-01-06 19:59:30,083 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_0_45.wav on instance 0
2021-01-06 20:00:03,536 [36] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 20:00:03,536 [35] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 20:00:03,537 [34] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 20:00:03,537 [15] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 20:00:03,559 [26] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 20:00:03,587 [6] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 20:00:03,605 [11] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 20:00:03,607 [23] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 20:00:03,635 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_0_46.wav on instance 0
2021-01-06 20:00:03,726 [19] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 20:00:03,741 [8] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 20:00:03,758 [27] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 20:00:03,758 [24] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 20:00:05,393 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_1_48.wav on instance 0
2021-01-06 20:01:57,682 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_1_49.wav on instance 0
2021-01-06 20:01:59,223 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_0_51.wav on instance 0
2021-01-06 20:02:18,686 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_0_52.wav on instance 0
2021-01-06 20:02:23,755 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_1_54.wav on instance 0
2021-01-06 20:02:27,696 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_1_55.wav on instance 0
2021-01-06 20:02:29,212 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_0_57.wav on instance 0
2021-01-06 20:02:33,176 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_0_58.wav on instance 0
2021-01-06 20:02:34,264 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_1_60.wav on instance 0
2021-01-06 20:04:17,553 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_1_61.wav on instance 0
2021-01-06 20:04:18,996 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_0_63.wav on instance 0
2021-01-06 20:07:07,782 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_0_64.wav on instance 0
2021-01-06 20:07:10,596 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_1_66.wav on instance 0
2021-01-06 20:07:23,485 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_1_67.wav on instance 0
2021-01-06 20:07:26,827 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_0_69.wav on instance 0
2021-01-06 20:07:45,733 [23] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 20:07:45,735 [11] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 20:07:45,740 [6] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 20:07:45,750 [26] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 20:07:45,886 [15] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 20:07:45,888 [34] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 20:07:45,891 [35] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 20:07:45,893 [36] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 20:07:46,086 [22] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 20:07:46,090 [21] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 20:07:46,093 [18] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 20:07:46,093 [14] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/4fb6ab72-15fe-3b70-b5d4-e2333734f5e2/desc – error = -204
2021-01-06 20:13:18,078 [15] DEBUG Audirvana.App - Error obtaining device description from http://192.168.2.10:8888/capability – error = -204
2021-01-06 20:13:18,079 [10] DEBUG Audirvana.App - Error obtaining device description from http://192.168.2.10:8888/capability – error = -204
2021-01-06 20:15:03,624 [15] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 20:15:03,627 [10] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 20:15:03,707 [12] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 20:15:03,709 [7] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 20:15:03,816 [13] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 20:15:03,817 [23] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 20:15:03,818 [14] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 20:15:03,849 [18] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 20:15:04,017 [21] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 20:15:04,049 [22] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 20:15:04,051 [36] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 20:15:04,052 [35] DEBUG Audirvana.App - Error obtaining device description from http://192.168.49.1:60000/upnp/dev/07db5e93-dea3-3047-a94a-38af826874a3/desc – error = -204
2021-01-06 20:15:24,574 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_0_70.wav on instance 0
2021-01-06 20:15:26,108 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_1_72.wav on instance 0
2021-01-06 20:15:37,404 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_1_73.wav on instance 0
2021-01-06 20:15:39,256 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_0_75.wav on instance 0
2021-01-06 20:15:47,071 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_0_76.wav on instance 0
2021-01-06 20:15:49,967 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_1_78.wav on instance 0
2021-01-06 20:15:57,563 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_1_79.wav on instance 0
2021-01-06 20:15:57,944 [22] DEBUG Audirvana.App - UPnP: error restarting playback when switching to next track
2021-01-06 20:15:58,737 [13] DEBUG Audirvana.App - UPnP: Error 401 resetting NextAVTransportURI when stopping
2021-01-06 20:16:12,419 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_1_82.wav on instance 0
2021-01-06 20:16:12,869 [23] DEBUG Audirvana.App - UPnP: error restarting playback when switching to next track
2021-01-06 20:16:13,677 [15] DEBUG Audirvana.App - UPnP: Error 401 resetting NextAVTransportURI when stopping
2021-01-06 20:16:24,590 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_1_85.wav on instance 0
2021-01-06 20:16:37,367 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_1_86.wav on instance 0
2021-01-06 20:16:37,735 [37] DEBUG Audirvana.App - UPnP: error restarting playback when switching to next track
2021-01-06 20:16:38,529 [15] DEBUG Audirvana.App - UPnP: Error 401 resetting NextAVTransportURI when stopping
2021-01-06 20:16:58,076 [1] DEBUG Audirvana.App - Error 401 setting NextAVTransportURI to http://192.168.2.14:49152/audirvana/audio_1_89.wav on instance 0
2021-01-06 20:18:06,598 [37] DEBUG Audirvana.App - UPnP select device: can’t find the device Hegel Max_H190 with UID: uuid:23d99ca4-1dd2-11b2-857c-f5f4bec0bcb6
2021-01-06 20:18:06,607 [22] DEBUG Audirvana.App - UPnP select device: can’t find the device Hegel Max_H190 with UID: uuid:23d99ca4-1dd2-11b2-857c-f5f4bec0bcb6
2021-01-06 20:18:06,908 [26] DEBUG Audirvana.App - Error obtaining device description from http://192.168.2.12:9080 – error = -107
2021-01-06 20:18:06,911 [6] DEBUG Audirvana.App - Error obtaining device description from http://192.168.2.12:9080 – error = -107
2021-01-06 20:18:07,479 [11] DEBUG Audirvana.App - Error obtaining device description from http://192.168.2.12:9080 – error = -107
2021-01-06 20:18:07,481 [19] DEBUG Audirvana.App - Error obtaining device description from http://192.168.2.12:9080 – error = -107
2021-01-06 20:18:07,483 [7] DEBUG Audirvana.App - Error obtaining device description from http://192.168.2.12:9080 – error = -107
2021-01-06 20:18:07,485 [6] DEBUG Audirvana.App - Error obtaining device description from http://192.168.2.12:9080 – error = -107
2021-01-06 20:18:07,487 [8] DEBUG Audirvana.App - Error obtaining device description from http://192.168.2.12:9080 – error = -107
2021-01-06 20:18:07,488 [9] DEBUG Audirvana.App - Error obtaining device description from http://192.168.2.12:9080 – error = -107
