So my question is fairly simple: Will Audirvana work in this sutiation:
I have i5NUC runnin windows 10 Pro headless-setup. I connect to it using desktop on other room via remote connection.
The nuc will be connected from USB to DAC. Now i need to control the audirvana app from my iPadPro. Is there an app that i can control it with? Or do i need to remote-connect the NUC for changing the songs etc.?
