I have Audirvana working in Windows 11. However, when I attempt to install the appropriate file in Fedora, by any means, it fails. Using a terminal, I get the following message:
$ sudo dnf install audirvana-studio-2.8.2.2-1.x86_64.rpm
Last metadata expiration check: 1:16:29 ago on Sun 07 Jul 2024 19:05:49.
Can not load RPM file: audirvana-studio-2.8.2.2-1.x86_64.rpm.
Could not open: audirvana-studio-2.8.2.2-1.x86_64.rpm
Am I missing something, or is there a problem with this download?
Indeed I do. I have downloaded more than once, checking carefully that I have the right version. There is no error message until I try the install via a terminal. That is what is puzzling me. Using the package manager it claims to have installed - with no trace when I check.
