Audirvana interrupts internet radio streaming
**Good morning, please help me resolve this issue. Audirvana is interrupting the streaming of the Cesky Rozhlas Jazz internet radio station. File attached. Best regards.**2023-06-26 17:44:28.759 [info]: ============= Started Logging, Audirvana Studio 2.3.4 (20304) macOS =============
2023-06-26 17:44:29.085 [info]: Remote started on port 54519
2023-06-26 17:45:00.163 [info]: UPnP web server started on 192.168.1.171:49152
2023-06-26 17:45:02.520 [error]: Mediakeys listening: error getting event Port
2023-06-26 17:45:02.772 [error]: Error getting volume uuid for /Volumes/Audirvana 2.3.4/ retrying once
2023-06-26 17:45:03.296 [error]: Error getting volume uuid for /Volumes/Audirvana 2.3.4/ retrying once
2023-06-26 17:45:46.932 [error]: UPnP Error 401 getting audio dB volume
2023-06-26 17:46:30.587 [info]: Remote App pairing request for device iPhone, pairing code is: 97 84 36
2023-06-26 17:47:06.034 [error]: Tidal getAlbumSimilarAlbums error: Similar albums for or album with id [641409] not found
2023-06-26 17:47:13.616 [error]: UPnP Error not implemented (401) setting NextAVTransportURI to http://192.168.1.171:49152/audirvana/audio_1.wav on instance 0
2023-06-26 17:48:55.477 [error]: UPnP Error not implemented (401) setting NextAVTransportURI to http://192.168.1.171:49152/audirvana/audio_1.pcm on instance 0
2023-06-26 17:48:55.477 [error]: UPnP AVTransport event: can’t parse filename http://192.168.1.171:49152/audirvana/audio_1.pcm for new AVTransportURI
2023-06-26 17:48:56.552 [error]: UPnP Error 501 starting playback
2023-06-26 17:48:56.552 [error]: UPnP error restarting playback when switching to next track
2023-06-26 17:49:06.520 [error]: UPnP Error 501 starting playback
2023-06-26 17:49:07.036 [error]: UPnP Error not implemented (401) setting NextAVTransportURI to on instance 0
2023-06-26 17:49:07.036 [warning]: UPnP Error resetting NextAVTransportURI when stopping
2023-06-26 17:49:33.425 [error]: UPnP Error 501 starting playback
2023-06-26 17:49:34.017 [error]: UPnP Error not implemented (401) setting NextAVTransportURI to on instance 0
2023-06-26 17:49:34.017 [warning]: UPnP Error resetting NextAVTransportURI when stopping
2023-06-26 17:50:01.735 [error]: UPnP Error 501 starting playback
2023-06-26 17:50:02.247 [error]: UPnP Error not implemented (401) setting NextAVTransportURI to on instance 0
2023-06-26 17:50:02.247 [warning]: UPnP Error resetting NextAVTransportURI when stopping
2023-06-26 17:50:27.426 [error]: UPnP select device: can’t find the device Hegel H120 with UID: uuid:1c47842e-1dd2-11b2-98e8-adc45e46e940
2023-06-26 17:50:30.418 [error]: UPnP Error 401 getting audio dB volume
2023-06-26 17:50:35.705 [error]: UPnP select device: can’t find the device Hegel H120 with UID: uuid:1c47842e-1dd2-11b2-98e8-adc45e46e940
2023-06-26 17:50:37.666 [error]: UPnP Error 401 getting audio dB volume
2026-05-22 23:49:08.147 [info]: ============= Started Logging, Audirvana Studio 3.1.0 (30100) macOS x86_64 =============
2026-05-23 00:06:26.068 [info]: ============= Started Logging, Audirvana Studio 3.1.0 (30100) macOS x86_64 =============
2026-05-24 13:05:08.988 [info]: ============= Started Logging, Audirvana Studio 3.1.0 (30100) macOS x86_64 =============
2026-05-24 18:47:19.912 [info]: ============= Started Logging, Audirvana Studio 3.1.0 (30100) macOS x86_64 =============
2026-05-26 13:32:18.063 [info]: ============= Started Logging, Audirvana Studio 3.1.0 (30100) macOS x86_64 =============
2026-05-26 13:52:32.145 [info]: ============= Started Logging, Audirvana Studio 3.1.0 (30100) macOS x86_64 =============
2026-05-27 09:11:17.336 [info]: ============= Started Logging, Audirvana Studio 3.1.0 (30100) macOS x86_64 =============
2026-05-27 10:33:57.202 [info]: ============= Started Logging, Audirvana Studio 3.1.0 (30100) macOS x86_64 =============
2026-05-27 12:11:13.755 [info]: ============= Started Logging, Audirvana Studio 3.1.0 (30100) macOS x86_64 =============
2026-05-29 10:34:42.736 [info]: ============= Started Logging, Audirvana Studio 3.1.0 (30100) macOS x86_64 =============
2026-06-02 14:23:42.549 [info]: ============= Started Logging, Audirvana Studio 3.1.0 (30100) macOS x86_64 =============
2026-06-07 21:21:08.018 [info]: ============= Started Logging, Audirvana Studio 3.1.0 (30100) macOS x86_64 =============
2026-06-11 10:26:39.704 [info]: ============= Started Logging, Audirvana Studio 3.2.0 (30200) macOS x86_64 =============
2026-06-12 08:09:27.177 [info]: ============= Started Logging, Audirvana Studio 3.2.0 (30200) macOS x86_64 =============
2026-06-12 19:03:42.905 [info]: ============= Started Logging, Audirvana Studio 3.2.0 (30200) macOS x86_64 =============
Hi @Freddie_Mercury ,
