I’m testing Origin.
I have a problem with syncing a large music folder (windows 11, i7, 32 Gb ram, library on Synology NAS). Is there such a thing as the “tail” command in Linux, that would enable verbose scaning and syncing? At some stage, the system seems to go offline and then freezes. Then I’m offered to view the dump file… I’ve browsed this file but it’s not realy explicit. Any suggestion that would help me find what is trigering this problem?
Thanks,
A.
Hello @Alexciara,
Can you send us your audirvana.dmp and audirvana.log file at [email protected]?
to show AppData folder:
