Slowly the program is no fun anymore! The support does not respond to mails!
What did I buy the software for? So that it crashes every time after 30-40 minutes!
Thanks Audirivana for not answering mails!
![Audirivana](https://community.audirvana.com/uploads/default/original/2X/4/4545760de1fd71e6c5b8e49d7fb40dd25763697f.png)
Debug Info
Audirvana 3.5.3
VST3 plugin #0: None
VST3 plugin #1: None
VST3 plugin #2: None
VST3 plugin #3: None
Sync list: 8 folders
AUTO: Z:\Alben\Deutsch
AUTO: Z:\Alben\Flac HighBit
AUTO: Z:\Alben\HipHop&Rap
AUTO: Z:\Alben\Interpret
AUTO: Z:\Alben\Jazz & Blues
AUTO: Z:\Alben\Klassik & Oper
AUTO: Z:\Alben\Pop&Rock+Folk
AUTO: Z:\Alben\R&B Soul
Library database path: C:\Users\xFreeezer\Datenbank\AudirvanaPlusDatabaseV2.sqlite
Preferred device: Neutron Music Player [DX160] (0D2BE2EF) Model UID:Neutron Code Limited Neutron Music Player [DX160] (0D2BE2EF) UID:uuid:9A0F96E5-A1B8-0EC7-8A51-980F53B04DFA
Currently playing to UPnP device at 24 bits 48kHz
UPnP device at http://192.168.1.75:49560/description.xml
Neutron Music Player [DX160] (0D2BE2EF) Manufacturer:Neutron Code Limited
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::audio/mp3:
http-get::audio/x-mp3:
http-get::audio/mpeg:
http-get::audio/mpeg3:
http-get::audio/x-ms-wma:
http-get::audio/wma:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/ogg:
http-get::audio/x-ogg:
http-get::application/octet-stream:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/musepack:
http-get::audio/x-musepack:
http-get::audio/wavpack:
http-get::audio/x-wavpack:
http-get::audio/ape:
http-get::audio/x-ape:
http-get::audio/mp4:
http-get::audio/m4a:
http-get::audio/x-alac:
http-get::audio/3gpp:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/aif:
http-get::audio/x-aif:
http-get::audio/x-caf:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/basic:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
2 ch Integer PCM 24bit little endian 352.8kHz
2 ch Integer PCM 24bit little endian 384kHz
2 ch DSD 8bit little endian in 8bit chunk 2822.4kHz
2 ch DSD 8bit little endian in 8bit chunk 5644.8kHz
2 ch DSD 8bit little endian in 8bit chunk 11289.6kHz
NrTracks: 1
MediaDuration: 00:03:06
CurrentURI: http://192.168.1.110:49152/audirvana/audio_1_20.wav
CurrentURIMetadata:
dc:titleSex Shooter</dc:title>
dc:creatorPrince</dc:creator>
upnp:artistPrince</upnp:artist>
upnp:genreR&B</upnp:genre>
upnp:albumArtURIhttp://192.168.1.110:49152/audirvana/artwork_1_21.jpg</upnp:albumArtURI>
upnp:albumOriginals 24Bit MQA</upnp:album>
nextURI: http://192.168.1.110:49152/audirvana/audio_0_21.wav
Jungle Love
Prince
Prince
R&B
http://192.168.1.110:49152/audirvana/artwork_0_22.jpg
Originals 24Bit MQA
2
object.item.audioItem.musicTrack
PlayMedium: NETWORK
RecordMedium: NONE
WriteStatus: NONE
<?xml version="1.0"?>
1
0
GetCurrentTransportActions
InstanceID
in
A_ARG_TYPE_InstanceID
Actions
out
GetDeviceCapabilities
InstanceID
in
PlayMedia
out
PossiblePlaybackStorageMedia
RecMedia
out
PossibleRecordStorageMedia
RecQualityModes
out
PossibleRecordQualityModes
GetMediaInfo
InstanceID
in
NrTracks
out
NumberOfTracks
MediaDuration
out
CurrentMediaDuration
CurrentURI
out
AVTransportURI
CurrentURIMetaData
out
AVTransportURIMetaData
NextURI
out
NextAVTransportURI
NextURIMetaData
out
NextAVTransportURIMetaData
PlayMedium
out
PlaybackStorageMedium
RecordMedium
out
RecordStorageMedium
WriteStatus
out
RecordMediumWriteStatus
GetPositionInfo
InstanceID
in
Track
out
CurrentTrack
TrackDuration
out
CurrentTrackDuration
TrackMetaData
out
CurrentTrackMetaData
TrackURI
out
CurrentTrackURI
RelTime
out
RelativeTimePosition
AbsTime
out
AbsoluteTimePosition
RelCount
out
RelativeCounterPosition
AbsCount
out
AbsoluteCounterPosition
GetTransportInfo
InstanceID
in
CurrentTransportState
out
TransportState
out
TransportStatus
CurrentSpeed
out
TransportPlaySpeed
GetTransportSettings
InstanceID
in
PlayMode
out
CurrentPlayMode
RecQualityMode
out
CurrentRecordQualityMode
Next
InstanceID
in
Pause
InstanceID
in
Play
InstanceID
in
Speed
in
TransportPlaySpeed
Previous
InstanceID
in
Seek
InstanceID
in
Unit
in
A_ARG_TYPE_SeekMode
Target
in
A_ARG_TYPE_SeekTarget
SetAVTransportURI
InstanceID
in
CurrentURI
in
AVTransportURI
CurrentURIMetaData
in
SetNextAVTransportURI
InstanceID
in
NextURI
in
NextAVTransportURI
NextURIMetaData
in
SetPlayMode
InstanceID
in
NewPlayMode
in
CurrentPlayMode
Stop
InstanceID
in
TransportStatus
string
OK
ERROR_OCCURRED
TransportState
string
STOPPED
PAUSED_PLAYBACK
PAUSED_RECORDING
PLAYING
RECORDING
TRANSITIONING
NO_MEDIA_PRESENT
TransportPlaySpeed
string
1
AVTransportURI
string
string
NextAVTransportURI
string
string
NumberOfTracks
ui4
0
4294967295
1
CurrentTrack
ui4
0
4294967295
1
CurrentTrackURI
string
string
string
string
CurrentPlayMode
string
NORMAL
NORMAL
string
i4
string
i4
string
string
UNKNOWN
HDD
NONE
NOT_IMPLEMENTED
string
ui4
string
A_ARG_TYPE_SeekMode
string
TRACK_NR
REL_TIME
string
0:EP
1:LP
2:SP
0:BASIC
1:MEDIUM
2:HIGH
string
UNKNOWN
HDD
NONE
NOT_IMPLEMENTED
RecordStorageMedium
string
UNKNOWN
HDD
NONE
NOT_IMPLEMENTED
string
WRITABLE
PROTECTED
NOT_WRITABLE
UNKNOWN
NOT_IMPLEMENTED
string
LastChange
string
1
0
http://neutroncode.com
5727
http://neutronmp.com
DMR-1.50
image/png
64
64
24
/dmr/media/upnp_icon.png
image/png
128
128
24
/dmr/media/upnp_icon_2x.png
/dmr/AVTransport/scpd.xml
/dmr/AVTransport/control
/dmr/AVTransport/event
/dmr/ConnectionManager/scpd.xml
/dmr/ConnectionManager/control
/dmr/ConnectionManager/event
/dmr/RenderingControl/scpd.xml
/dmr/RenderingControl/control
/dmr/RenderingControl/event
UPnP devices found : 2
Device #0Neutron Music Player [DX160] (0D2BE2EF) UID: uuid:9A0F96E5-A1B8-0EC7-8A51-980F53B04DFA Location: http://192.168.1.75:49560/description.xml
Device #1LG 55B7D UID: uuid:2993eee8-d15c-6d03-33cc-b8feb1863186 Location: http://192.168.1.34:1195/
Max. memory for audio buffers: 62300MB
Local Audio Engine:ASIO -2147481291 driver version 374
Local devices found : 0
