Audirvana Mac Version 3.5.33 (3563)
macOS 10.15.4 with 8192MB RAM
Registered to
AUTO: /Volumes/MMV/Music (FLAC)
Library database path: /Users/rickb/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Modi Multibit
Model UID:Modi Multibit:0D8C:0004
UID:AppleUSBAudioEngine:Schiit Audio:Modi Multibit:14600000:1
Hog Mode is on
ID 0x2b Modi Multibit Manufacturer:Schiit Audio
Model UID:Modi Multibit:0D8C:0004 UID:AppleUSBAudioEngine:Schiit Audio:Modi Multibit:14600000:1
Stream ID 0x2c 2 channels starting at 1
24 virtual formats:
36 physical formats
Local devices found : 3
Device #0: ID 0x50 G257HU Manufacturer: Apple Inc. Model UID: AppleGFXHDA:0 UID: AppleGFXHDAEngineOutputDP:f803:0:{7204-0416-8190000D}
Device #1: ID 0x2b Modi Multibit Manufacturer: Schiit Audio Model UID: Modi Multibit:0D8C:0004 UID: AppleUSBAudioEngine:Schiit Audio:Modi Multibit:14600000:1
Device #2: ID 0x4a Mac mini Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
Edited to add: Device #0 is my monitor. It is made by Acer, not Apple.
