Hi to all,
after a clean install of my mac I installed Audirvana again. Downloaded it again but at the point to import the license key comes “No valid … found”.
For version 3 ist there a new key needed?
Thanks and regards …Carsten
Hi to all,
Yes, version 3 is a major upgrade, and is thus a paid upgrade
If you want to stay with version 2, you can get the 2.6.6 at https://audirvana.com/delivery/AudirvanaPlus_2.6.6.dmg
Thanks.
I wil look for the new features / difference.
