What a mess. Was not enough to have songs stopping four seconds before the end, then getting the famous two pops in middle of songs and then moving with no demand to next track, now music is all distorted, impossible to listen to. On Qobuz and
library music. With ASIO. No issue with WASAPI.
Audirvana 3.5.45
Bandwidth at 0dB = 90.007
Phase = 0
AUTO: E:\backup-003836
Library database path: C:\Users\jeanf\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 2016MB
Local Audio Engine:ASIO 2 driver version 2
T+A PDP3000 USB ASIO
Model UID:T+A PDP3000 USB ASIO
Active Sample Rate: 2822.4kHz
T+A PDP3000 USB ASIO Manufacturer:
Model UID:T+A PDP3000 USB ASIO UID:T+A PDP3000 USB ASIO
13 available sample rates up to 45158400Hz
5644800
11289600
22579200
45158400
DSD capability: Raw DSD (MSB)
2 ch DSD 8bit big endian in 8bit chunk 45158.4kHz
Device #0: T+A PDP3000 USB ASIO Manufacturer: Model UID: T+A PDP3000 USB ASIO UID: T+A PDP3000 USB ASIO
Device #1: TEAC ASIO USB DRIVER Manufacturer: Model UID: TEAC ASIO USB DRIVER UID: TEAC ASIO USB DRIVER
