Hi Damien,
Thanks for the quick response. The firewall settings are as you have detailed they should be below.
Here is the debug info
macOS 10.15.6 with 8192MB RAM
Registered to Christopher I Parker
Manual: (OFFLINE) /Volumes/TOSHIBA EXT/Music/Music/iTunes/iTunes Music
Library database path: /Users/chrisparker/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Livingroom
Model UID:Devialet Livingroom
UID:uuid:366f7cbc80314bf0b65d8c3af0bfc7ff2d756e6976657273616c6c79737065616b696e6772656e6465726572
ID 0x30 Built-in Output Manufacturer:Apple Inc.
Model UID:AppleHDA:51 UID:AppleHDAEngineOutput:1F,3,0,1,1:0
3 available sample rates up to 96000Hz
Stream ID 0x31 2 channels starting at 1
3 virtual formats:
3 physical formats
Device #0: ID 0x30 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:51 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
