Ok. So I’ve reinstalled Audirvana and factory reset the KEF’s, still no audio.
Here’s the debug:
Audirvana Mac Version 1.6.1 (10601)
macOS 11.5.1 with 16384MB RAM
Bandwidth at 0dB = 99.5%
Phase = 66%
Replay Gain: by track
AUTO: /Volumes/Audirvana Database 2TB/
Library database path: /Volumes/Audirvana Database 2TB/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49597
Max. memory for audio buffers: 15360MB
AUDIOQUEST AUDIOQUEST DRAGONFLY COBALT V1.0
Model UID:AudioQuest DragonFly Cobalt v1.0:21B4:0085
UID:AppleUSBAudioEngine:AudioQuest:AudioQuest DragonFly Cobalt v1.0:AQDFCB0100103921:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 6 bytes per frame 96kHz
Active Sample Rate: 96kHz
Hog Mode is on
ID 0x32 AudioQuest DragonFly Cobalt v1.0
Manufacturer: AudioQuest
Model Name: AudioQuest DragonFly Cobalt v1.0
Model UID: AudioQuest DragonFly Cobalt v1.0:21B4:0085
UID: AppleUSBAudioEngine:AudioQuest:AudioQuest DragonFly Cobalt v1.0:AQDFCB0100103921:1
MQA Renderer device
Stream ID 0x33 2 channels starting at 1
8 virtual formats:
8 physical formats
Local devices found : 4
Device #0: ID 0x71 DELL U2417H Manufacturer: Apple Inc. Model UID: AppleGFXHDA:0 UID: AppleGFXHDAEngineOutputDP:f803:0:{AC10-40E7-3538314C} Model Name: Apple Inc. DELL U2417H
Device #1: ID 0x32 AudioQuest DragonFly Cobalt v1.0 Manufacturer: AudioQuest Model UID: AudioQuest DragonFly Cobalt v1.0:21B4:0085 UID: AppleUSBAudioEngine:AudioQuest:AudioQuest DragonFly Cobalt v1.0:AQDFCB0100103921:1 Model Name: AudioQuest DragonFly Cobalt v1.0
Device #2: ID 0x36 CalDigit Thunderbolt 3 Audio Manufacturer: CalDigit, Inc. Model UID: CalDigit Thunderbolt 3 Audio:2188:6533 UID: AppleUSBAudioEngine:CalDigit, Inc.:CalDigit Thunderbolt 3 Audio:200000:1 Model Name: CalDigit, Inc. CalDigit Thunderbolt 3 Audio
Device #3: ID 0x58 MacBook Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. MacBook Pro Speakers
UPnP devices found : 2
Device #0: ID 0x0 [TV] Samsung 6 Series (55) UID: uuid:323e3ee0-8139-4f36-8e7b-4fd49a30aa4a Location: http://192.168.1.92:9197/dmr
Device #1: ID 0x0 LS50 Wireless II-1509ae UID: uuid:45c7d3ca-cc73-49af-b4be-8dfcbece6779 Location: http://192.168.1.128:43811/45c7d3ca-cc73-49af-b4be-8dfcbece6779.xml
