macOS 12.4.0 with 32768MB RAM
Registered to steve freedman
Sync list: 0 folders
Library database path: /Users/stevefreedman/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Exclusive access: Disabled
Benchmark DAC2 USB 1.0 Audio Out
Model UID:Benchmark DAC2 USB Audio 1.0:1781:0E4E
UID:AppleUSBAudioEngine:Benchmark DAC2 :Benchmark DAC2 USB Audio 1.0:0000:1
Active Sample Rate: 48kHz
ID 0x56 Benchmark DAC2 USB 1.0 Audio Out Manufacturer:Benchmark DAC2
Model UID:Benchmark DAC2 USB Audio 1.0:1781:0E4E UID:AppleUSBAudioEngine:Benchmark DAC2 :Benchmark DAC2 USB Audio 1.0:0000:1
Stream ID 0x57 2 channels starting at 1
8 virtual formats:
8 physical formats
Device #0: ID 0x56 Benchmark DAC2 USB 1.0 Audio Out Manufacturer: Benchmark DAC2 Model UID: Benchmark DAC2 USB Audio 1.0:1781:0E4E UID: AppleUSBAudioEngine:Benchmark DAC2 :Benchmark DAC2 USB Audio 1.0:0000:1
Device #1: ID 0x4a iMac Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
