Any help would be appreciated if anyone knows how to get DSD to play on the Topping DX7 Pro on my Macmini. I’m using Audirvana and it doesn’t seem to work regardless of which settings I select in Audirvana… Thanks
Hello @Huynh,
If your DAC is compatible with DSD over PCM, you can set the native DSD read method to “DSD over PCM 1.0” in the device section of the audio settings page.
If your DAC has a volume control, you may need to ensure it is set at 100% during DSD playback to prevent its USB interface from damaging the DSD signal.
