Hi All
I can see that with Audirvana Origin 2.2.2, Integer Mode is ‘Off’, and I can’t work out how it can be enabled. I’ve tried searching for an answer and have been unable to locate anything of relevance. Please see my Debug Info below:
Audirvana Origin 2.2.2 (20202)
macOS 13.0.1 with 8GB physical RAM
Connected account of : Tim Stapleton
AUTO: /Volumes/timchristinestapleton/Music/Audio Library - T & C Stapleton
Library database path: /Users/timstapleton/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49223
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Actual I/O buffer frame size: 4096
Apple Inc. MRX x10 AVR
Model UID:AppleGFXHDA:0
UID:AppleGFXHDAEngineOutputDP:f803:0:{8D06-0000-00000000}
Device: 8ch Mixable linear PCM Interleaved 32bits little endian Signed Float, 32 bytes per frame 44.1kHz
Hog Mode is on
Sample rate switching latency: 0.5s
Limit bitdepth to 24bit: ON
Selected device:MRX x10 AVR
Model name: Apple Inc. MRX x10 AVR
Model UID: AppleGFXHDA:0
UID: AppleGFXHDAEngineOutputDP:f803:0:{8D06-0000-00000000}
ID 0x78
7 available sample rates up to 192000Hz
32000
Multichannel: 8 channels
Channel 2 unused
Channel 3 unused
Channel 4 unused
Channel 5 unused
Channel 6 unused
Channel 7 unused
Number of channels: 8
Simple stereo device: No
Stream ID 0x79 8 channels starting at 1
10 virtual formats:
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 192kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 176.4kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 96kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 88.2kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 44.1kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 32kHz
17 physical formats
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 192kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 176.4kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 96kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 88.2kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 44.1kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 32kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 192kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 176.4kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 96kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 88.2kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 44.1kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 32kHz
Local devices found : 3
Device #0: ID 0x78 MRX x10 AVR
Device #1: ID 0x6c MacBook Air Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. MacBook Air Speakers
Device #2: ID 0x31 Microsoft Teams Audio
Manufacturer: Microsoft Corp.
UPnP devices found : 1
Device #0: ID 0x0 : MRX 740-41FC56
UID: uuid:8ec6e5c5-f1b0-4800-9fe3-092c77eac6c3
Location: http://192.168.1.107:37121/8ec6e5c5-f1b0-4800-9fe3-092c77eac6c3.xml
Manufacturer: Anthem
Model name: MRX 740
Chromecast devices found : 1
Device #0: MRX 740-41FC56
Model name: MRX 740
