Hi there,
Origin is cutting out a couple of minutes into a tune. It the can’t be restarted without closing the app and starting again. Unfortunately, the same thing then happens.
I’d be grateful for any help with this. I’ve payed my debug info below. Cheers
Audirvana Origin 1.0.6 (10006)
macOS 10.15.7 with 16GB physical RAM
Connected account of : Paul Stephenson
Bandwidth at 0dB = 99.5%
Phase = 72%
Replay Gain: by album
AUTO: /Volumes/music-1/PaulsMusic
Library database path: /Users/paulstephenson/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 50264
Max. memory for audio buffers: 12254MB
Peachtree 24/192 USB X
Model UID:Peachtree 24/192 USB X:20B1:0002
UID:AppleUSBAudioEngine:Peachtree 24/192 :Peachtree 24/192 USB X:0000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 44.1kHz
Hog Mode is on
Sample rate switching latency: 2s
ID 0xcc Peachtree 24/192 USB X
Manufacturer: Peachtree 24/192
Model Name: Peachtree 24/192 USB X
Model UID: Peachtree 24/192 USB X:20B1:0002
UID: AppleUSBAudioEngine:Peachtree 24/192 :Peachtree 24/192 USB X:0000:1
Stream ID 0xcd 2 channels starting at 1
12 virtual formats:
12 physical formats
Local devices found : 4
Device #0: ID 0xc5 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutput:1B,0,1,2:0 Model Name: Apple Inc. Built-in Output
Device #1: ID 0xcc Peachtree 24/192 USB X Manufacturer: Peachtree 24/192 Model UID: Peachtree 24/192 USB X:20B1:0002 UID: AppleUSBAudioEngine:Peachtree 24/192 :Peachtree 24/192 USB X:0000:1 Model Name: Peachtree 24/192 USB X
Device #2: ID 0x29 Soundflower (2ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:0 Model Name: ma++ ingalls for Cycling '74 Soundflower (2ch)
Device #3: ID 0x34 Soundflower (64ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:1 Model Name: ma++ ingalls for Cycling '74 Soundflower (64ch)
UPnP devices found : 1
Device #0: ID 0x0 LSX 0287F6 UID: uuid:5f9ec1b3-ed59-1900-4530-8417150287f6 Location: http://192.168.0.223:8080/description.xml
