Goodafternoon,
I encountered the following bug, my Devialet Phantom 108db are not recognized by Audirvana Origin they where recognized in the studio version.
Could this be solved.
Kind regards,
Shulaf
Goodafternoon,
Kind regards,
Shulaf
I’m using the windows version, and found a solution.
You need to type in the op adres of the Phantom and in the web gui you need to reconnect wifi. The audirvana tech team should should work with Devialet to find a more stable solution
This issue should have been solved since a really long time now. Which version of DOS are you using.
I’m using 2.14.4 in this version it still occurs
