Hi Demian,
Here I am again.
I have purchased Audirvana, however this example is using the Trial on a PC-Windows 10.
PC is connected to Elite Pioneer Receiver SC-97 with HDMI cable out from NVIDIA 1070 card.
Samsung TV connected to Receiver HDMI Main Out.
Debug follows below.
When I play a file on Foobar2000 and then turn the TV the audio momentarily cuts off and then resumes, no problem.
If I play a file on Audirvana [Audio Setting-WASAPI-DAC SC-97] and then turn the TV off, the audio cuts off and it does not return???
The only difference is the software playing the file.<<<<<<
HDMI Inputs do not change in the receiver, as they do for example if I select in Audirvana Audio Settings, Network SC-97. In that case the receiver automatically changes the Input to DMR. The video from PC goes Off and instead the TV shows an SC-97 image of whats playing, etc.
DEBUG
Audirvana 3.5.44
Sync list: 2 folders
AUTO: G:\Music fr Russell
AUTO: \macpro\music\Music FLAC
Library database path: C:\Users\Juan\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 6386MB
Local Audio Engine:WASAPI
SC-97 (NVIDIA High Definition Audio)
Model UID:SC-97 (NVIDIA High Definition Audio)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{7fb9a4bd-3aec-4911-a7a2-cdd15857e57e}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device: 2ch 16bits Integer, 4 bytes per frame 44.1kHz
SC-97 (NVIDIA High Definition Audio) Manufacturer:
Model UID:SC-97 (NVIDIA High Definition Audio) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{7fb9a4bd-3aec-4911-a7a2-cdd15857e57e}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Simple stereo device: No
Device #0: Realtek Digital Output(Optical) (Realtek High Definition Audio) Manufacturer: Model UID: Realtek Digital Output(Optical) (Realtek High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{e0ee2daf-d5ae-4092-961a-d9ac22a1ac58}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: SC-97 (NVIDIA High Definition Audio) Manufacturer: Model UID: SC-97 (NVIDIA High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{7fb9a4bd-3aec-4911-a7a2-cdd15857e57e}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
UPnP devices found : 1
Device #0Pioneer SC-97 UID: uuid:5F9EC1B3-ED59-79BB-4530-745e1c591673 Location: http://192.168.2.13:8080/description.xml
