(Tidal)I use the latest version of Audirvana plus to play songs on my MacBook Pro, but many of the songs lose part after loading and the songs become incomplete. Why?
Hello @Richard_M,
Do you mean that when you try to play tracks form Tidal in Audirvana it doesn’t load properly?
Can you send me a copy of the “Debug Info” while you have the issue? You can get it in Audirvana Settings>General>Debug Info
Hi, same was happening here with Tidal.
Part of the song was reproduced properly but the time bar at the bottom of the screen was ‘loading’ only partially, the playback was stopping when the bar was reaching the point where the loading was apparently blocked. Now i moved the Max memory allocated for tracks pre-load fm abt 44 to 52 mn and it seems to work again.
Audirvana 3.5.45
AUTO: D:
Library database path: C:\Users\shabi\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 2126MB
Local Audio Engine:ASIO 2 driver version 1091
Pro-Ject Box ASIO Driver
Model UID:Pro-Ject Box ASIO Driver
Device: 2ch 32bits Integer, 8 bytes per frame 705.6kHz
Active Sample Rate: 705.6kHz
Pro-Ject Box ASIO Driver Manufacturer:
Model UID:Pro-Ject Box ASIO Driver UID:Pro-Ject Box ASIO Driver
2822400
5644800
11289600
22579200
DSD capability: Raw DSD (MSB)
Local devices found : 3
Device #0: ASIO4ALL v2 Manufacturer: Model UID: ASIO4ALL v2 UID: ASIO4ALL v2
Device #1: BRAVO-HD Manufacturer: Model UID: BRAVO-HD UID: BRAVO-HD
Device #2: Pro-Ject Box ASIO Driver Manufacturer: Model UID: Pro-Ject Box ASIO Driver UID: Pro-Ject Box ASIO Driver
UPnP devices found : 2
Device #0Swisscom Box 2 UID: uuid:7b71af90-fa26-11dd-9536-b988ec20ba27 Location: http://192.168.1.107:52138/aw
Device #1[TV]UE46D7000 UID: uuid:305d4535-350f-6ed4-6adf-5df7ed95b064 Location: http://192.168.1.103:52235/dmr/SamsungMRDesc.xml
What I mean is that most of the songs appear short after the hifi sound quality is loaded
