Hi, Audirvana does not work well with Marantz PM7000N.
I can’t control the volume gradually, for example: when I try to increase it from 32 to 34 or 36, the software goes back to volume 32, and only allows me to jump to volume 45. A message appears saying that I’m trying to increase it suddenly the volume, which is not true. Volume control is basic. I’m seriously thinking about abandoning the software because of this huge problem.
Furthermore, i can no longer use any plug-in while playing a music again, simply dont’t show the plug-in popup. I remember that at one time you had resolved this, but now the problem has returned.
Hi @duchuchebu,
Audirvana Studio 2.8.2 (20802)
Windows 10 (19045) with 16GB physical RAM
Connected account of : Alex Lins
Available network interfaces:
brisa-1742405 ({3551f873-0135-474d-bafb-a5f463fef662}) is private
Active profile types: all
Private profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Third party firewall installed and registered in place of Windows Defender:
Kaspersky Standard
VST3 plugin #0: C:\Program Files\Common Files\VST3\MeldaProduction\EQ\MDynamicEq.vst3
ClassID: 4D656C646170726F4D6479514D647951
VST3 plugin #1: None
VST3 plugin #2: None
VST3 plugin #3: None
Bandwidth at 0dB = 99.5%
Phase = 66%
Max allowed volume: 73.1469
SW volume control: ON
AUTO: C:\Users\AlexLins\Documents\DRmare TidiKit Music Converter\Converted
Library database path: C:\Users\AlexLins\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Tracks with no MBID: 164
Listening on 2804:29b8:5161:9c4:24d2:80f2:11a7:c0f0 on port 57008
TIDAL: Connected as PREMIUM
Font size: regular
My Music
Radios
Podcasts
Streaming
Number of paired remotes: 1
Screen saver disabled: no
Active method: UPnP
Preferred device: [UPnP] Marantz PM7000N Model UID:Marantz Marantz PM7000N UID:uuid:4d7b0675-1c74-1160-0080-0005cdb3dbd6
Currently playing to UPnP device at 16 bits 192kHz
Selected device:Marantz PM7000N
Manufacturer: Marantz
Model name: Marantz PM7000N
Model UID: Marantz Marantz PM7000N
UID: uuid:4d7b0675-1c74-1160-0080-0005cdb3dbd6
UPnP device at http://192.168.0.4:60006/upnp/desc/aios_device/aios_device.xml
Volume control: Yes
UPnP set capabilities
Maximum PCM bitdepth set: 16
Not native DSD capable
Avoid RAW PCM streams: No
Unwanted playback stop workaround: Yes
http-get::audio/mpeg:
http-get::audio/x-ms-wma:
http-get::audio/L16;rate=48000;channels=2:
http-get::audio/L16;rate=48000;channels=1:
http-get::audio/L16;rate=44100;channels=2:
http-get::audio/L16;rate=44100;channels=1:
http-get::audio/wav:
http-get::audio/mp3:
http-get::audio/flac:
http-get::audio/aac:
http-get::audio/m4a:
DLNA 1.5: No
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
Volume Control: scalar
NrTracks: 1
MediaDuration: 00:00:00
CurrentURI: http://192.168.0.15:49152/audirvana/audio_f_4.wav
CurrentURIMetadata: dc:titleClair De Lune</dc:title>http://192.168.0.15:49152/audirvana/audio_f_4.wavupnp:classobject.item.audioItem.musicTrack</upnp:class>dc:creatorLord Vinheteiro</dc:creator>upnp:genre""</upnp:genre>upnp:artistLord Vinheteiro</upnp:artist>upnp:albumClair De Lune</upnp:album>upnp:albumArtURIhttp://resources.tidal.com/images/53dfea34/ed13/4b78/b772/7bfbc272ced6/640x640.jpg</upnp:albumArtURI>upnp:originalTrackNumber1</upnp:originalTrackNumber>
nextURI: http://192.168.0.15:49152/audirvana/audio_f_5.wav
nextURIMetadata: dc:titleDur Dur D'etre Un Bebe</dc:title>http://192.168.0.15:49152/audirvana/audio_f_5.wavupnp:classobject.item.audioItem.musicTrack</upnp:class>dc:creatorJordi</dc:creator>upnp:genre""</upnp:genre>upnp:artistJordi</upnp:artist>upnp:albumNº1 90's Vol.12</upnp:album>upnp:albumArtURIhttp://resources.tidal.com/images/0ddcbf48/d1b9/4b90/9ab2/d90bc22ad354/640x640.jpg</upnp:albumArtURI>upnp:originalTrackNumber24</upnp:originalTrackNumber>
PlayMedium: NETWORK
Current transport actions:
Play,Stop,Next,Previous,Pause,Restart
<?xml version="1.0"?>1
0
urn:schemas-denon-com:device:AiosDevice:1
Marantz PM7000N
Marantz
Marantz PM7000N
Aios 4.025
BLL27190900280
Marantz PM7000N
Marantz
Marantz PM7000N
Aios 4.025
uuid:bd84ddb6-c891-1b76-0080-0005cdb3dbd6
qq:X_QPlay_SoftwareCapabilityQPlay:1</qq:X_QPlay_SoftwareCapability>
/upnp/scpd/renderer_dvc/AVTransport.xml
/upnp/control/renderer_dvc/AVTransport
/upnp/event/renderer_dvc/AVTransport
/upnp/scpd/renderer_dvc/ConnectionManager.xml
/upnp/control/renderer_dvc/ConnectionManager
/upnp/event/renderer_dvc/ConnectionManager
/upnp/scpd/renderer_dvc/RenderingControl.xml
/upnp/control/renderer_dvc/RenderingControl
/upnp/event/renderer_dvc/RenderingControl
urn:schemas-denon-com:device:AiosServices:1
AiosServices
Marantz
Marantz PM7000N
Aios 4.025
uuid:4b2ad4aa-1fc3-1eee-0080-0005cdb3dbd6
urn:schemas-denon-com:service:ErrorHandler:1
urn:denon-com:serviceId:ErrorHandler
/upnp/scpd/AiosServicesDvc/ErrorHandler.xml
/upnp/control/AiosServicesDvc/ErrorHandler
/upnp/event/AiosServicesDvc/ErrorHandler
urn:schemas-denon-com:service:ZoneControl:2
urn:denon-com:serviceId:ZoneControl
/upnp/scpd/AiosServicesDvc/ZoneControl.xml
/upnp/control/AiosServicesDvc/ZoneControl
/upnp/event/AiosServicesDvc/ZoneControl
urn:schemas-denon-com:service:GroupControl:1
urn:denon-com:serviceId:GroupControl
/upnp/scpd/AiosServicesDvc/GroupControl.xml
/upnp/control/AiosServicesDvc/GroupControl
/upnp/event/AiosServicesDvc/GroupControl
urn:schemas-denon-com:device:ACT-Denon:1
Marantz PM7000N
Marantz
Marantz PM7000N
Aios 4.025
BLL27190900280
uuid:77cfb03f-186d-408d-d12f-e5a82b56477f
AIOS:0001
<capability_version>2</capability_version>
1715779858
<firmware_date>Thu 2024-05-16 00:31:04</firmware_date>
<firmware_version>3.19.350</firmware_version>
00:05:CD:B3:DB:D4
en_NA
4
Aios 4.025
1
Production
00:05:CD:B3:DB:D6
urn:schemas-denon-com:service:ACT:1
urn:denon-com:serviceId:ACT
/ACT/SCPD.xml
/ACT/control
/ACT/event
urn:schemas-upnp-org:device:MediaServer:1
Marantz PM7000N
Marantz
Shares User defined folders and files to other Universal Plug and Play media devices.
Marantz PM7000N
Aios 4.025
BLL27190900280
uuid:cb238573-c03e-bbed-ddac-9f72c1c6a021
<avega_media_server:X_VirtualServersSupported>True</avega_media_server:X_VirtualServersSupported>
urn:schemas-upnp-org:service:ContentDirectory:1
urn:upnp-org:serviceId:ContentDirectory
/upnp/scpd/ams_dvc/ContentDirectory.xml
/upnp/control/ams_dvc/ContentDirectory
/upnp/event/ams_dvc/ContentDirectory
/upnp/scpd/ams_dvc/ConnectionManager.xml
/upnp/control/ams_dvc/ConnectionManager
/upnp/event/ams_dvc/ConnectionManager
0
Marantz PM7000N
Marantz
Marantz PM7000N
Aios 4.025
BLL27190900280
Marantz PM7000N
Marantz
Marantz PM7000N
Aios 4.025
AiosServices
Marantz
Marantz PM7000N
Aios 4.025
Marantz PM7000N
Marantz
Marantz PM7000N
Aios 4.025
BLL27190900280
AIOS:0001
1715779858
00:05:CD:B3:DB:D4
en_NA
4
Aios 4.025
1
Production
00:05:CD:B3:DB:D6
/ACT/SCPD.xml
/ACT/control
/ACT/event
Marantz PM7000N
Marantz
Marantz PM7000N
Aios 4.025
BLL27190900280
UPnP devices found : 1
Device #0: Marantz PM7000N
Location: http://192.168.0.4:60006/upnp/desc/aios_device/aios_device.xml
Max. memory for audio buffers: 10460MB
Local Audio Engine: WASAPI
Device #0: Alto-falantes (High Definition Audio Device)
Manufacturer: Microsoft
Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_15586555&REV_1003
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{7ffb51b3-46a2-47e1-b7e0-e0edb69b2505}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Áudio Digital (S/PDIF) (High Definition Audio Device)
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{ab60acf9-b134-4ba6-8593-2865a3ac3f55}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Can you disable the software volume control in Audirvāna and check if you still have your behavior?
Were you playing a song when you made the screenshot?
on Marantz
Please click on the lock icon at the bottom right of Audirvāna and try to disable the software volume control.
The “Software Volume Controle” button is disabled when I select marantz pm7000n device.
If you try to put the max volume limit at 100% and change the volume control +/- step to 1 dB, does it helps?
Looks like it resolved, I no longer detected the problem. Thank! As for that other problem, I can’t use any plug-in while playing a music, simply dont’t show the plug-in popup during execution. Besides, I think plug-in not are working even at background.
Antoine, need I open another topic to treat about this issue (plug-in problem) ?
Not needed. As you are playing to a UPNP endpoint, you can’t see your plugin while you are playing to such output. However If you disable the option and make changes to the plugin without music playing, then you will hear the changes made by the plugin.
