I use Audirvana 3.5 on PC and Mac.
One issue that does not work is to stop the playback properly with the remote and then change to a different UPnP playback device. It looks to me the remote just pauses the playback and therefore it remains active. So I have to go back to my PC or Mac and stop the playback there. This really stops the playback and a new device can be selected with the remote.
This problem was present in older versions.
It is still not repaired.
Please fix this issue.
thank you
@Damien
Please repair this issue.
The remote is unusable for me, because I cant switch between UPnP devices.
The app just pauses the playback, it does not stop it.
I have to go back to the Mac to stop playback each time I need to change the playback device.
Thanks a lot for fixing this issue.
Works now.
Same problem , I’m streaming audirvana to a Cambridge audio cxn great sound yet the remote app on iPhone won’t let you stop the track or even pause doesn’t work . Annoying
