Help please. I Start any album (any library or Tidal) from MacBook Pro and the album tracks play through the album correctly. I can also select tracks from MacBook Pro with out a problem. Make any change using remote on iPad or iPhone (except for volume and pause) and Audirvana gets confused and then skips every other track and shows the wrong song in track list menu. It will not recover until I restart Audirvana from the MacBook and use only the MacBook to initiate and manage music. Why is the remote causing confusion using UPnP/DLNA? Thanks anyone
