Please enable Audirvana Remote to be installed on Huawei. It’s not difficult for you, but we need it.
Hello @Mickle,
If you are using a new Huawei that can’t sue the Google Store then you won’t be able to use the Remote as we do not plan to make our app available on the store used by Huawei.
Ок, значит мы обойдемся без Audirvana.
You can try to sideload the remote app on your phone:
