Hi,
I have two problems with Audirvana remote:
1.The only way to connect to Audirvana Server is the following procedure:
- I close Adirvana. Then I start remote app and wait until it says “cannot connect”. Then I start Audirvana at the server again and the remote app connects readily without any human interaction . Starting the server first and the remote app afterwards does not work. (“Use bonjour” is flagged in the settings. )
- When the connction is etablished, the app runs for a while ( few minutes), then the connection is lost and can only restored by the procedure described above.
btw: Sometimes it says “Application is not licensed”, but not in every case.
I recently installed everything, so I have the actual versions.
I run Audirvana on WIndows 10 and the remote app under Andoid 9.
Both are in the same network.
In the same environment Jriver and Jriver Remote run without problems.
Any help somewhere ? ( I know the issue is already described several times…)
Kind Regards to Audirvana Support.
Dieter
