Audirvana remote app on my iphone connects to my audirvana app running on my mac mini fine.
I can search, filter, view playlists, etc.
But I can’t get it to actually play any tunes. Pressing on a song doesn’t cause it to start planing, pressing the play button doesn’t do anything, etc. Any thoughts?
Thanks.
Audirvana Mac Version 3.5.29 (3559)
macOS 10.15.3 with 32768MB RAM
AUTO: /Volumes/macbt/audio
iTunes/Music library synchronization: last synchronized on Fri Dec 13 00:34:04 2019
Library database path: /Users/pbg/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: ropieeexl [RoPieeeXL] Model UID:Ivo Clarysse, Henner Zeller ropieeexl [RoPieeeXL] UID:uuid:0a9fc316-4de7-42f5-976f-ae3b0258f428
UPnP device at http://192.168.1.54:49495/description.xml
ID 0x0 ropieeexl [RoPieeeXL] Manufacturer:Ivo Clarysse, Henner Zeller
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::audio/:*
http-get::audio/AMR:
http-get::audio/AMR-WB:
http-get::audio/G722:
http-get::audio/G723:
http-get::audio/G729:
http-get::audio/L16;rate=44100;channels=2:
http-get::audio/ac3:
http-get::audio/alac:
http-get::audio/dsd:
http-get::audio/m4a:
http-get::audio/mp4:
http-get::audio/mpeg:
http-get::audio/ogg:
http-get::audio/webm:
http-get::audio/x-ac3:
http-get::audio/x-adpcm:
http-get::audio/x-alac:
http-get::audio/x-alaw:
http-get::audio/x-amr-nb-sh:
http-get::audio/x-amr-wb-sh:
http-get::audio/x-au:
http-get::audio/x-bv:
http-get::audio/x-celt:
http-get::audio/x-dts:
http-get::audio/x-eac3:
http-get::audio/x-flac:
http-get::audio/x-gsm:
http-get::audio/x-iLBC:
http-get::audio/x-m4a:
http-get::audio/x-matroska:
http-get::audio/x-mpeg:
http-get::audio/x-mulaw:
http-get::audio/x-nellymoser:
http-get::audio/x-opus:
http-get::audio/x-pn-realaudio:
http-get::audio/x-private1-ac3:
http-get::audio/x-private1-dts:
http-get::audio/x-raw:
http-get::audio/x-sbc:
http-get::audio/x-scpls:
http-get::audio/x-siren:
http-get::audio/x-speex:
http-get::audio/x-tta:
http-get::audio/x-unaligned-raw:
http-get::audio/x-vorbis:
http-get::audio/x-wav:
http-get::audio/x-wavpack:
http-get::audio/x-wma:
DLNA 1.5: No
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
22 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 705.6kHz
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 768kHz
0 physical formats
NrTracks: 0
MediaDuration:
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NOT_IMPLEMENTED
<?xml version="1.0"?> 1 0 GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Pause InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData Stop InstanceID in A_ARG_TYPE_InstanceID SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData TransportStatus string OK ERROR_OCCURRED vendor-defined NextAVTransportURI string NextAVTransportURIMetaData string CurrentTrackMetaData string RelativeCounterPosition i4 A_ARG_TYPE_InstanceID ui4 A_ARG_TYPE_SeekTarget string PlaybackStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED vendor-defined RelativeTimePosition string PossibleRecordStorageMedia string CurrentPlayMode string NORMAL REPEAT_ALL INTRO NORMAL TransportPlaySpeed string 1 vendor-defined PossiblePlaybackStorageMedia string AbsoluteTimePosition string CurrentTrack ui4 0 4294967295 1 CurrentTrackURI string CurrentTransportActions string NumberOfTracks ui4 0 4294967295 AVTransportURI string AbsoluteCounterPosition i4 CurrentRecordQualityMode string 0:EP 1:LP 2:SP 0:BASIC 1:MEDIUM 2:HIGH NOT_IMPLEMENTED vendor-defined CurrentMediaDuration string A_ARG_TYPE_SeekMode string ABS_TIME REL_TIME ABS_COUNT REL_COUNT TRACK_NR CHANNEL_FREQ TAPE-INDEX FRAME AVTransportURIMetaData string RecordStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED vendor-defined RecordMediumWriteStatus string WRITABLE PROTECTED NOT_WRITABLE UNKNOWN NOT_IMPLEMENTED LastChange string CurrentTrackDuration string TransportState string STOPPED PLAYING TRANSITIONING PAUSED_PLAYBACK PAUSED_RECORDING RECORDING NO_MEDIA_PRESENT PossibleRecordQualityModes stringCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 ropieeexl [RoPieeeXL] Ivo Clarysse, Henner Zeller http://github.com/hzeller/gmrender-resurrect gmediarender 0.0.8 gmediarender 0.0.8_git2019-10-29_5129386 http://github.com/hzeller/gmrender-resurrect uuid:0a9fc316-4de7-42f5-976f-ae3b0258f428 image/png 64 64 24 /upnp/grender-64x64.png image/png 128 128 24 /upnp/grender-128x128.png urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upnp/rendertransportSCPD.xml /upnp/control/rendertransport1 /upnp/event/rendertransport1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/renderconnmgrSCPD.xml /upnp/control/renderconnmgr1 /upnp/event/renderconnmgr1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upnp/rendercontrolSCPD.xml /upnp/control/rendercontrol1 /upnp/event/rendercontrol1 http://192.168.1.54:49495/UPnP devices found : 2
Device #0: ID 0x0 ropieeexl [RoPieeeXL] UID: uuid:0a9fc316-4de7-42f5-976f-ae3b0258f428 Location: http://192.168.1.54:49495/description.xml
Device #1: ID 0x0 CX-A5200 EE54E6 UID: uuid:9ab0c000-f668-11de-9976-44fe3bee54e6 Location: http://192.168.1.237:49154/MediaRenderer/desc.xml
Device #0: ID 0x47 Mac mini Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
10.15.3 beta…
what iOS system ?
to make this > 20 characters I’m typing in some other stuff.
ios 13.3
You think being on the betas is causing the problem?
can’t say, maybe… Damien might be better for answer this
i’m on 10.15.2 and ios 13.3 with no problem… have you tried trashing the app from iphone… hard shut down iphone, then restart iphone, redownload the app and see?
there should be a code asked also if i remember…
