Hello,
Same story today. Restarting the network switch does not help.
Devices initially appeared in the list under “ethernet”, then after switch to “Wifi” and back to “Ethernet”, all devices are gone…
Restarting Audirvana is the solution. Issue with Catalina or problems with the MAc Mini going into sleep mode?
Hey, Eric. Do you use a Mac? You didnt notice it. You described something, that seems to be normal. If I want change the Macbook-Output from USB to Network-Player, I have to restart the Mac. I suppose, its not an Audirvana-Problem, indeed one by MacOS. I use the older MacOS Mojave.
Hey Dirk. Yes, I’m using a MacMini with Catalina.
I’m a bit surprised with what you say. I did not know that a reboot was needed to switch from USB to a network device.
On my side, I simply need to restart Audirvana to perform a switch. I have to say “I now need to restart” as it was not the case before. And I’m not using USB devices.
Now, I always need to restart Audirvana to switch to a network device. All network devices appear to be available but cannot be selected, only the Mac Mini loudspeakers are usable.
I’m going to try an upgrade to Catalina 10.15.6 to see if this can solve the issue.
Can you check the firewall settings: In System Preferences > Security and Privacy > Firewall > Firewall Options > Automatically allow signed software to receive incoming connections check that this setting is selected and “Block all incoming connections” is not selected.
Thanks Damien,
But my firewall is not activated on this machine. Maybe an issue with a switch? I already experienced a problem with a switch where my MacBook pro was not able to reach the network. I suspected a failure of my network card on the MAcbook, but it was a problem coming from the power supply of the switch.
I precise that the failed switch I’m talking about here is not the one I’m using, which seems to work fine as other applications do not have a problem to reach the network devices.
I ordered a new switch and I will see if that fixes the problem.
Apparently, there is also an update of Catalina 10.15.6 which I’m requested to install on my Mac Mini.
I’ll keep you informed.
Thanks anyway.
Dear all,
I captured a video when the problem occurs (Apparently, changing the switch and upgrade OSX did nit help).
But, unfortunately, it cannot be uploaded to the forum.
If somebody knows how to do…
