If we play 16bit/44.1kHz FLAC files with a “Focusrite Scarlett Solo USB” Audirvana shows “24/44.1kHz Stereo Int” in the bottom right corner.
This makes me a little bit unsure.
Will this say, that 24 bit are sent to the Focusrite DAC or what does the “24” mean?
Under Linux it is not possible to send 24 bit towards the Focusrite (format not supported), we must send 32 bit. Ok, this may be an error in the Linux Sound system. But also the lines of the Audirvana debug output (24 little endian Signed Integer aligned low in 32bit 44.1kHz) make me suspect that 32bit are sent to the DAC.
Does anyone have an explanation?
This is the log:
Audirvana Mac Version 3.5.34 (3564)
macOS 10.15.4 with 16384MB RAM
Registered to ***********
AUTO: /Users/rene/MyMusicAudirvana
Library database path: /Users/rene/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Scarlett Solo USB
Model UID:Scarlett Solo USB:1235:8211
UID:AppleUSBAudioEngine:Focusrite:Scarlett Solo USB:Y7UAYVW950E595:1,2
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 44.1kHz
Hog Mode is on
ID 0x3a Scarlett Solo USB Manufacturer:Focusrite
Model UID:Scarlett Solo USB:1235:8211 UID:AppleUSBAudioEngine:Focusrite:Scarlett Solo USB:Y7UAYVW950E595:1,2
Stream ID 0x3b 2 channels starting at 1
12 virtual formats:
12 physical formats
Device #0: ID 0x30 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:128 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x3a Scarlett Solo USB Manufacturer: Focusrite Model UID: Scarlett Solo USB:1235:8211 UID: AppleUSBAudioEngine:Focusrite:Scarlett Solo USB:Y7UAYVW950E595:1,2
