First of all on my mac mini it took 24hrs to load music info (about 4000 albums) from a connected hard drive! In the activity monitor disk read/write data it showed about 200gb written. Has anyone had this experience ? Was so much data written somewhere or is it a “buffering” activity?
Secondly, True-Fi does work initially with normal sample rates. When asked to play hi-res tracks audirvana crashes and there is no sound output even though the track is “playing”. The only way to get back any sound is to quit True-Fi and reset audirvana.
the 2gb is your A+ library… back it up
Mine is 1.5gb for 2900 albums i think. It is located in your Home Folder…
ooups i see now you said 200gb… that was surely buffering… just check your main folders weight to see if it is still taken place somewhere…
