As a prior Roon user and now Audirvana, I can say that Roon’s interface is superior, but Audirvana sounds better when connected directly to a DAC via USB. Roon’s architecture is designed as client/server vs Audirvana. Given this, testing multiple end points (roonpieXL, Bryston BDP-3, NUC PC (no moving parts), etc.) vs Audirvana running on a fanless PC (like a NUC) with a audiophile USB card, separate LPS powering the USB card, Audirvana sounds better to me. All other components remained the same. I even tried other software JCAT FEMTO, Amarra, Volumio, Daphile, but none other sounded as good or had a user interface close to Roon or Audirvana that I liked. Hope this helps.
Hi Matt,
JCAT FEMTO USB with Allo Shanti LPS powering the card separately. There are other LPS power supply but I chose this one given its an LPS and relatively less expensive than others.
Hi Ian,
yes, the Shanti is very good and not expensive and I would not hesitate to power even the new, very expensive JCAT USB CARD XE with it.
It is also my impression that Audirvana sounds best and I like the UI with Qobuz.
i’m using Tidal instead of Qobuz. Would you know if there is any difference in UI? I recently purchased an inexpensive DAC (Pro-ject Pre Box S2 Digital) for my computer, but used it in line with my system to hear how it sounded and was very impressed. I also used MQA on the DAC with Audirvana and thought it was different, but not necessarily better. Maybe more listening time is required.
I use a MacBook Pro/A3.5.33/Qobuz with upsampling deactivated into a Khadas Tone Board DAC and like it.
Most impressions from Audiophile Style and Lejonklou forum report that Qobuz sounds superior to Tidal. I dislike the policy of MQA so Tidal is no option for me.
Just downloaded Audirvana and Roon. I agree Audirvana sounds much better. And Roon is 10x better as far as interface/GUI goes. Plus, Roon can cast to Google devices which is also nice. I’m going back and forth between them. I really wish Audirvana would improve the interface and ease of use!
Roon is nice but more expensive per month. Sound quality is great Gui good be better. But i am using it because of the sound not because there is a nice gui.
So far so good i am gonna stick with this. If you sent Damien a message he is always helping you out. So kudos for him
Just want to add. I came from Roon & La Rosita System (Engine & DAC). That was a good sound.
Then I found a better DAC from Artistic Fidelity in combination with a windows based audiophile computer as source. Here I compared Roon, River, and Audirvana. And Audirvana topped all of them clearly. Till a miracle for me why this is the case. But the music has so much more flow, fundament and holographic stiffness. It is pure joy. I never went back to test anything else - I want to spend that time better for listening. BUT: Yes I miss the good database features from Roon a bit. But I also thought that the price for Roon is just over the top. Thats not worth it…
Regards
Sebastian
