Helio: I wonder if somebody can Help me: Audirvana stops sounding. The progress bar keeps scrolling and the system keeps playing the song, but there is no sound at all.
This happens within a minute or two of starting any topic.
What can I do? Maybe reinstall Audirvana?
Many thanks,
Anton.
My sistema is Audirvana for mac and my DAC is ifI.
Can you dump the debug info here?
macOS 10.13.6 with 8192MB RAM
Registrado a Anton Beiras Cal
iZotope SRC not in use iZotope SRC filter parameters
Steepness = 150
Filter max length = 500000
Cut-Off (x Nyquist) = 100%
Anti-aliasing = 200
Phase = 100%
Replay Gain: by track
Sync list: 6 folders
AUTO: /Volumes/MacHD/antonbeiracal/Dropbox/Delicatessen/Brothers In Arms (SACD)
AUTO: /Volumes/MacHD/antonbeiracal/Dropbox/Delicatessen/Champion Jack Dupree
AUTO: /Volumes/MacHD/antonbeiracal/Dropbox/Delicatessen/Mariinsky (Kirov) Theater Orchestra
AUTO: /Volumes/MacHD/antonbeiracal/Dropbox/Delicatessen/Ronnie Earl & The Broadcasters
AUTO: /Volumes/MacHD/antonbeiracal/Music
Manual: (OFFLINE) /Users/antonbeiracal/Music/iTunes 12-10-2017/Music
iTunes/Music library synchronization: last synchronized on Tue Nov 3 11:36:06 2020
Library database path: /Volumes/MacHD/antonbeiracal/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
iFi (by AMR) HD USB Audio Output
UID:AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 44.1kHz
Hog Mode is on
Limit bitdepth to 24bit: ON
ID 0x43 iFi (by AMR) HD USB Audio Output Manufacturer:iFi (by AMR)
Model UID:iFi (by AMR) HD USB Audio:20B1:3008 UID:AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
MQA Renderer device
Stream ID 0x44 2 channels starting at 1
16 virtual formats:
16 physical formats
Device #0: ID 0x2f Salida integrada Manufacturer: Apple Inc. Model UID: AppleHDA:78 UID: AppleHDAEngineOutput:8,0,1,2:0
Device #1: ID 0x43 iFi (by AMR) HD USB Audio Output Manufacturer: iFi (by AMR) Model UID: iFi (by AMR) HD USB Audio:20B1:3008 UID: AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
Helio bitracer, Can you please help me?
Many thanks!
Antón.
Reduce pre-load cache to 2000MB. Make sure that upsampling is disabled.
Done, but doesn’t work!
Sound fades away 1 minute after initialize playback. Playback continues: progress bar is moving, but no sound at all.
Anton.
Disable integer mode. See if that helps.
No! The same thing always happens; one minute after starting playback, the sound is turned off, although the task bar continues to advance and the display shows the seconds running.
Antón.
PS: Should I delete and reinstall the audirvana app?
Have you tried to play using another device, like built in audio/speakers?
Playing from the tidal desktop app there are no interruptions in the sound. Only with Audirvana. Also Audirvana is not responding. I think it’s corrupted. I needed authorization and instructions to completely uninstall Audirvana and install it again.
My license Key (Audirvana 3.0) is this: 0JBVY-5VGJ4-QQ6Y2-3M9TG-6SCZA
