Thank you for the care you take. It make trust to your app.
All the best.
Pierre
All the best.
Pierre
Hi,
I am also using a Lumin T2. I have no issue but listening much more through Roon than Audirvana (UpnP from PC) at the moment. Let me know if I can do anything to help.
I tried the Linux app on my QNAP NAS, and it was also working well but reverted to PC based because I want to test direct to USB as a next sound quality check.
Anyway let me know if I can help!
Hi Rog,
Well, when i look at the log, I see there is minim server involved, the ip adress is the NAS and not the computer with Audirvana, Audirvana is not supposed to use minim server computer is connected via SMB on the NAS, i use the minim server when i play from the Lumin App…
I was not playing the file described on the 3rd line (Casagrande), and it is not on the playlist either.
2024-05-06 09:24:19.596 [warning]: UPnP failed to send file info for not found fileLoader for trackId 5
2024-05-06 09:24:19.598 [warning]: UPnP failed to send file info for not found fileLoader for trackId 5
2024-05-06 09:24:38.276 [error]: UPnP AVTransport event: can’t parse filename http://192.168.1.73:9790/minimserver/*/_Selections/05*20Actuel/Casagrande/*3eHome/1-04*20Casagrande*20-*20Bliss.flac for new AVTransportURI
2024-05-06 09:27:06.363 [error]: UPnP select device: can’t find the device Pixel Magic Systems Ltd. T2 with UID: uuid:4c494e4e-3d9b-11e1-b86c-0016e862fcbb
2024-05-06 09:27:30.649 [error]: UPnP Error 501 getting audio dB volume range
2024-05-06 09:27:30.670 [error]: Error subscribing to RenderingControl events on http://192.168.1.23:23000/RenderingControl/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/event.xml
2024-05-06 09:40:22.099 [error]: UPnP audio device unreachable (powered off ?), aborting playing position monitoring
2024-05-06 09:40:22.121 [error]: UPnP select device: can’t find the device Pixel Magic Systems Ltd. T2 with UID: uuid:4c494e4e-3d9b-11e1-b86c-0016e862fcbb
2024-05-06 09:40:27.362 [error]: UPnP select device: can’t find the device Pixel Magic Systems Ltd. T2 with UID: uuid:4c494e4e-3d9b-11e1-b86c-0016e862fcbb
I see that Audirvana loose the conection with the Lumin, just before the playing stop (it still can play a few minutes but there is no more info from Audirvana, it’s like there was noting on play) and i cannot see the Lumin in the output choice in the bottom right, there is nothing wrong on the Lumin display…
I have never this kind of problem on the other system with a Marantz ND8006. … And it is rather new on the Lumin, can’t say if it come from a update on it or Audirvana sometimes i can play a whole album without problem sometimes, not even one track. The computer is from 2013 so there is no more update on it.
I have a very long ethernet wire to the Lumin, like about 15 meter, it goes to another floor… but have never this kind of problem with Lumin…
That’s become quite annoying, i reall prefer to use Audirvana than Lumin most of the time.
Thanks for your comment
Hi @pierrest,
First off, just a disclaimer that I am just a regular user trying to help.
Did you try switching off the minim server on your Synology?
My Lumin T2 is with firmware 17.2, which is the latest. Do you have the same?
Yes i do the update regulary. Sinology is restartet regulary too.
It’s good to know that works with your config, it may come from something in my “chain”
@Antoine I just realised that this track we see in the log that is looking for (Casagrande) is the first track of the Lumin App playlist. Like the Lumin was sending a wrong information back to Audirvana…
