Ok, hereâs the debug info file:
Audirvana Studio 2.8.1 (20801)
macOS 10.15.7 with 16GB physical RAM
Connected account of : Pierre Steulet
Per track: OFF
No plugin active
Max allowed volume: 46.2963
AUTO: /Volumes/music/_Selections
Library database path: /Users/steulet/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 8286
Listening on 127.0.0.1 on port 63574
Font size: large
Language: Langue du systĂšme
Ma Musique
Radios
Podcasts
Streaming
Startup view: BibliothĂšque locale : Albums
Use media keys for volume control: no
Use Apple Remote: no
Number of paired remotes: 2
Screen saver disabled: no
Active method: UPnP
Preferred device: [UPnP] LUMIN T2:LUMIN Model UID:Pixel Magic Systems Ltd. T2 UID:uuid:4c494e4e-3d9b-11e1-b86c-0016e862fcbb
Currently playing to UPnP device at 32 bits 88.2kHz
Selected device:LUMIN T2:LUMIN
Manufacturer: Pixel Magic Systems Ltd.
Model name: T2
Model UID: Pixel Magic Systems Ltd. T2
UID: uuid:4c494e4e-3d9b-11e1-b86c-0016e862fcbb
UPnP device at http://192.168.1.23:23000/
ID 0x0
Volume control: Yes
Max volume alert: Disabled
Raw DSD (msb)
UPnP set capabilities
Maximum PCM frequency set: 384000Hz
Maximum PCM bitdepth set: 32
Maximum DSD rate set: DSD512
Avoid RAW PCM streams: No
Unwanted playback stop workaround: Yes
http-get:::*
http-get::audio/mpeg:
http-get::audio/mpeg3:
http-get::audio/mp3:
http-get::audio/x-mp3:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/mp4:
http-get::audio/mpeg4-generic:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aac:
http-get::audio/alac:
http-get::audio/x-alac:
http-get::audio/dsd:
http-get::audio/x-dsf:
http-get::audio/x-dff:
http-get::application/octet-stream:
http-get::audio/opus:
DLNA 1.5: Yes
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
28 virtual formats:
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 44.1kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 88.2kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 176.4kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 352.8kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 48kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 96kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 192kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 384kHz finite length
2 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 11289.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 22579.2kHz finite length
0 physical formats
NrTracks: 33
MediaDuration: 00:03:11
CurrentURI: http://192.168.1.36:49152/audirvana/audio_f_347.wav
CurrentURIMetadata:
dc:titleAtomic Voyage</dc:title>
dc:creatorTrees Speak</dc:creator>
upnp:artistTrees Speak</upnp:artist>
upnp:genreExperimental</upnp:genre>
upnp:albumArtURIhttp://192.168.1.36:49152/audirvana/artwork_0_347.jpg</upnp:albumArtURI>
upnp:albumVertigo of Flaws</upnp:album>
upnp:originalTrackNumber17</upnp:originalTrackNumber>
nextURI: http://192.168.1.36:49152/audirvana/audio_f_348.wav
Ultraviolet
Trees Speak
Trees Speak
Experimental
http://192.168.1.36:49152/audirvana/artwork_1_348.jpg
Vertigo of Flaws
18
object.item.audioItem.musicTrack
PlayMedium: NONE
Current transport actions:
Play,Pause,Stop,Seek,Next,Previous
<?xml version="1.0"?>
1
1
LUMIN T2:LUMIN
https://www.luminmusic.com/
LUMIN
T2
1.0
DMR-1.50
image/png
120
120
24
/images/lumin-120x120.png
image/png
48
48
24
/images/lumin-48x48.png
/AVTransport/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/scpd.xml
/AVTransport/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/control.xml
/AVTransport/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/event.xml
/ConnectionManager/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/scpd.xml
/ConnectionManager/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/control.xml
/ConnectionManager/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/event.xml
/RenderingControl/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/scpd.xml
/RenderingControl/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/control.xml
/RenderingControl/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/event.xml
urn:av-openhome-org:service:Product:1
urn:av-openhome-org:serviceId:Product
/Product/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/scpd.xml
/Product/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/control.xml
/Product/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/event.xml
urn:av-openhome-org:service:Playlist:1
urn:av-openhome-org:serviceId:Playlist
/Playlist/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/scpd.xml
/Playlist/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/control.xml
/Playlist/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/event.xml
urn:av-openhome-org:service:Time:1
urn:av-openhome-org:serviceId:Time
/Time/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/scpd.xml
/Time/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/control.xml
/Time/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/event.xml
urn:av-openhome-org:service:Info:1
urn:av-openhome-org:serviceId:Info
/Info/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/scpd.xml
/Info/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/control.xml
/Info/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/event.xml
urn:av-openhome-org:service:Volume:1
urn:av-openhome-org:serviceId:Volume
/Volume/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/scpd.xml
/Volume/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/control.xml
/Volume/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/event.xml
urn:av-openhome-org:service:Transport:1
urn:av-openhome-org:serviceId:Transport
/Transport/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/scpd.xml
/Transport/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/control.xml
/Transport/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/event.xml
urn:magictv-com:service:MagicAudio:1
urn:magictv-com:serviceId:MagicAudio
/MagicAudio/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/scpd.xml
/MagicAudio/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/control.xml
/MagicAudio/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/event.xml
urn:av-openhome-org:service:Credentials:1
urn:av-openhome-org:serviceId:Credentials
/Credentials/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/scpd.xml
/Credentials/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/control.xml
/Credentials/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/event.xml
urn:av-openhome-org:service:Radio:1
urn:av-openhome-org:serviceId:Radio
/Radio/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/scpd.xml
/Radio/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/control.xml
/Radio/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/event.xml
urn:av-openhome-org:service:Receiver:1
urn:av-openhome-org:serviceId:Receiver
/Receiver/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/scpd.xml
/Receiver/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/control.xml
/Receiver/4c494e4e-3d9b-11e1-b86c-0016e862fcbb/event.xml
1
1
LUMIN T2:LUMIN
LUMIN
T2
1.0
DMR-1.50
image/png
120
120
24
image/png
48
48
24
UPnP devices found : 2
Device #0: ID 0x0 : Marantz ND8006
UID: uuid:5fb42a9a-b815-1069-0080-0005cdc130d6
Location: http://192.168.1.20:60006/upnp/desc/aios_device/aios_device.xml
Manufacturer: Marantz
Model name: Marantz ND8006
Device #1: ID 0x0 : LUMIN T2:LUMIN
Model name: T2
Max. memory for audio buffers: 15360MB
Local Audio Engine: CoreAudio
Device #0: ID 0x30 Sortie intégrée
Model UID: AppleHDA:7
Model name: Apple Inc. Sortie intégrée
Device #1: ID 0xa2 ND8006
Manufacturer: D&M Holdings Inc.
Model UID: ND8006:154E:300A
UID: AppleUSBAudioEngine:D&M Holdings Inc.:ND8006:14300000:1
USB Vendor ID: 0x154e
USB Product ID: 0x300a
Model name: D&M Holdings Inc. ND8006
