Hi @Antoine!
Thanks for taking a look at this. As requested, here is my debug log.
Audirvana Mac Version 3.5.34 (3564)
macOS 10.14.6 with 8192MB RAM
AUTO: /Volumes/Music/Music
Library database path: /Users/darren/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: ropieee [RoPieeeXL] Model UID:Ivo Clarysse, Henner Zeller ropieee [RoPieeeXL] UID:uuid:0e6ced92-2184-448d-b04d-3c93b8cd54fb
UPnP device at http://192.168.147.101:49494/description.xml
ID 0x0 ropieee [RoPieeeXL] Manufacturer:Ivo Clarysse, Henner Zeller
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::audio/:*
http-get::audio/AMR:
http-get::audio/AMR-WB:
http-get::audio/G722:
http-get::audio/G723:
http-get::audio/G729:
http-get::audio/L16;rate=44100;channels=2:
http-get::audio/ac3:
http-get::audio/aiff:
http-get::audio/alac:
http-get::audio/dsd:
http-get::audio/m4a:
http-get::audio/mp4:
http-get::audio/mpeg:
http-get::audio/ms-gsm:
http-get::audio/ogg:
http-get::audio/qcelp:
http-get::audio/webm:
http-get::audio/x-ac3:
http-get::audio/x-adpcm:
http-get::audio/x-aiff:
http-get::audio/x-alac:
http-get::audio/x-alaw:
http-get::audio/x-amr-nb-sh:
http-get::audio/x-amr-wb-sh:
http-get::audio/x-au:
http-get::audio/x-bfstm:
http-get::audio/x-brstm:
http-get::audio/x-bv:
http-get::audio/x-celt:
http-get::audio/x-dpcm:
http-get::audio/x-dsd:
http-get::audio/x-dts:
http-get::audio/x-dv:
http-get::audio/x-eac3:
http-get::audio/x-ffmpeg-parsed-ape:
http-get::audio/x-ffmpeg-parsed-musepack:
http-get::audio/x-flac:
http-get::audio/x-gsm:
http-get::audio/x-gst-av-mp3adufloat:
http-get::audio/x-gst-av-mp3on4float:
http-get::audio/x-gst-av-vmdaudio:
http-get::audio/x-gst-av-ws_snd1:
http-get::audio/x-iLBC:
http-get::audio/x-imc:
http-get::audio/x-m4a:
http-get::audio/x-mace:
http-get::audio/x-matroska:
http-get::audio/x-mlp:
http-get::audio/x-mpeg:
http-get::audio/x-mulaw:
http-get::audio/x-musepack:
http-get::audio/x-nellymoser:
http-get::audio/x-opus:
http-get::audio/x-pn-realaudio:
http-get::audio/x-private1-ac3:
http-get::audio/x-private1-dts:
http-get::audio/x-qdm2:
http-get::audio/x-raw:
http-get::audio/x-rf64:
http-get::audio/x-sbc:
http-get::audio/x-scpls:
http-get::audio/x-shorten:
http-get::audio/x-sipro:
http-get::audio/x-siren:
http-get::audio/x-smpte-302m:
http-get::audio/x-speex:
http-get::audio/x-true-hd:
http-get::audio/x-truespeech:
http-get::audio/x-tta:
http-get::audio/x-ttafile:
http-get::audio/x-twin-vq:
http-get::audio/x-unaligned-raw:
http-get::audio/x-vnd.sony.atrac1:
http-get::audio/x-vnd.sony.atrac3:
http-get::audio/x-voc:
http-get::audio/x-vorbis:
http-get::audio/x-voxware:
http-get::audio/x-wav:
http-get::audio/x-wavpack:
http-get::audio/x-wavpack-correction:
http-get::audio/x-wma:
http-get::audio/x-wms:
DLNA 1.5: No
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
14 virtual formats:
0 physical formats
NrTracks: 0
MediaDuration:
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NOT_IMPLEMENTED
<?xml version="1.0"?>
1
0
GetCurrentTransportActions
InstanceID
in
A_ARG_TYPE_InstanceID
Actions
out
GetDeviceCapabilities
InstanceID
in
PlayMedia
out
PossiblePlaybackStorageMedia
RecMedia
out
PossibleRecordStorageMedia
RecQualityModes
out
PossibleRecordQualityModes
GetMediaInfo
InstanceID
in
NrTracks
out
NumberOfTracks
MediaDuration
out
CurrentMediaDuration
CurrentURI
out
AVTransportURI
CurrentURIMetaData
out
AVTransportURIMetaData
NextURI
out
NextAVTransportURI
NextURIMetaData
out
NextAVTransportURIMetaData
PlayMedium
out
PlaybackStorageMedium
RecordMedium
out
RecordStorageMedium
WriteStatus
out
RecordMediumWriteStatus
GetPositionInfo
InstanceID
in
Track
out
CurrentTrack
TrackDuration
out
CurrentTrackDuration
TrackMetaData
out
CurrentTrackMetaData
TrackURI
out
CurrentTrackURI
RelTime
out
RelativeTimePosition
AbsTime
out
AbsoluteTimePosition
RelCount
out
RelativeCounterPosition
AbsCount
out
AbsoluteCounterPosition
GetTransportInfo
InstanceID
in
CurrentTransportState
out
TransportState
out
TransportStatus
CurrentSpeed
out
TransportPlaySpeed
GetTransportSettings
InstanceID
in
PlayMode
out
CurrentPlayMode
RecQualityMode
out
CurrentRecordQualityMode
Pause
InstanceID
in
Play
InstanceID
in
Speed
in
TransportPlaySpeed
Seek
InstanceID
in
Unit
in
A_ARG_TYPE_SeekMode
Target
in
A_ARG_TYPE_SeekTarget
SetAVTransportURI
InstanceID
in
CurrentURI
in
AVTransportURI
CurrentURIMetaData
in
Stop
InstanceID
in
SetNextAVTransportURI
InstanceID
in
NextURI
in
NextAVTransportURI
NextURIMetaData
in
TransportStatus
string
OK
ERROR_OCCURRED
vendor-defined
NextAVTransportURI
string
string
string
i4
ui4
string
string
UNKNOWN
DV
MINI-DV
VHS
W-VHS
S-VHS
D-VHS
VHSC
VIDEO8
HI8
CD-ROM
CD-DA
CD-R
CD-RW
VIDEO-CD
SACD
MD-AUDIO
MD-PICTURE
DVD-ROM
DVD-VIDEO
DVD-R
DVD+RW
DVD-RW
DVD-RAM
DVD-AUDIO
DAT
LD
HDD
MICRO-MV
NONE
NOT_IMPLEMENTED
vendor-defined
string
string
CurrentPlayMode
string
NORMAL
REPEAT_ALL
INTRO
NORMAL
TransportPlaySpeed
string
1
vendor-defined
string
string
CurrentTrack
ui4
0
4294967295
1
CurrentTrackURI
string
string
NumberOfTracks
ui4
0
4294967295
AVTransportURI
string
i4
string
0:EP
1:LP
2:SP
0:BASIC
1:MEDIUM
2:HIGH
NOT_IMPLEMENTED
vendor-defined
string
A_ARG_TYPE_SeekMode
string
ABS_TIME
REL_TIME
ABS_COUNT
REL_COUNT
TRACK_NR
CHANNEL_FREQ
TAPE-INDEX
FRAME
string
RecordStorageMedium
string
UNKNOWN
DV
MINI-DV
VHS
W-VHS
S-VHS
D-VHS
VHSC
VIDEO8
HI8
CD-ROM
CD-DA
CD-R
CD-RW
VIDEO-CD
SACD
MD-AUDIO
MD-PICTURE
DVD-ROM
DVD-VIDEO
DVD-R
DVD+RW
DVD-RW
DVD-RAM
DVD-AUDIO
DAT
LD
HDD
MICRO-MV
NONE
NOT_IMPLEMENTED
vendor-defined
string
WRITABLE
PROTECTED
NOT_WRITABLE
UNKNOWN
NOT_IMPLEMENTED
LastChange
string
string
TransportState
string
STOPPED
PLAYING
TRANSITIONING
PAUSED_PLAYBACK
PAUSED_RECORDING
RECORDING
NO_MEDIA_PRESENT
string
1
0
ropieee [RoPieeeXL]
http://github.com/hzeller/gmrender-resurrect
gmediarender 0.0.8
gmediarender
0.0.8_git2020-03-13_adbf252
image/png
64
64
24
/upnp/grender-64x64.png
image/png
128
128
24
/upnp/grender-128x128.png
/upnp/rendertransportSCPD.xml
/upnp/control/rendertransport1
/upnp/event/rendertransport1
/upnp/renderconnmgrSCPD.xml
/upnp/control/renderconnmgr1
/upnp/event/renderconnmgr1
/upnp/rendercontrolSCPD.xml
/upnp/control/rendercontrol1
/upnp/event/rendercontrol1
UPnP devices found : 2
Device #0: ID 0x0 ropieee [RoPieeeXL] UID: uuid:0e6ced92-2184-448d-b04d-3c93b8cd54fb Location: http://192.168.147.101:49494/description.xml
Device #1: ID 0x0 Humax RVU Client MediaRenderer UID: uuid:MediaRenderer-40_3D_EC_2F_64_5F Location: http://169.254.7.14:63445/upnp/xml/devices/MediaRenderer1.xml
Device #0: ID 0x2e Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:16 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
