Audirvana 3.5.38
Per track: OFF
VST3 plugin #0: C:\Program Files\Common Files\VST3\SonEQFree.vst3
ClassID: F2AEE70D00DE4F4E536F6E69536F4551
VST3 plugin #1: None
VST3 plugin #2: None
VST3 plugin #3: None
Sync list: 0 folders
Library database path: C:\Users\svein\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 3110MB
Local Audio Engine:WASAPI
iFi (by AMR) HD USB Audio
Model UID:iFi (by AMR) HD USB Audio
Active Sample Rate: 48kHz
DAC (iFi (by AMR) HD+ USB Audio) Manufacturer:
Model UID:DAC (iFi (by AMR) HD+ USB Audio) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{1a4acbba-8c60-47a5-bcb5-9b6fbd25b83e}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
MQA Renderer device
Simple stereo device: No
Device #0: DAC (iFi (by AMR) HD+ USB Audio) Manufacturer: Model UID: DAC (iFi (by AMR) HD+ USB Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{1a4acbba-8c60-47a5-bcb5-9b6fbd25b83e}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
