After upgrading my hardware to Macbook Air M2 + Apple Studio Display, I am unable to listen music using the Studio Display speakers. Audirvana 3.5 immediately stops the audio device. Other devices such as the Macbook Air speakers, Apple Homepod and Cambridge Audio CXA81 work fine.
Any suggestion?
Thanks,
Stefano
PS: same problem with Audirvana Origin
macOS 13.0.1 with 16384MB RAM
Registered to Stefano Frega
AU plugin #0: Effect - Sonimus Sweetone ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
Replay Gain: by album
SW volume control: ON
Sync list: 2 folders
AUTO: /Users/stefanofrega/Music/Musica iMac
AUTO: /Volumes/Musica/Musica Audirvana
Library database path: /Users/stefanofrega/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Studio Display Speakers
Model UID:Studio Display Audio Control:05AC:1114
UID:AppleUSBAudioEngine:Apple Inc.:Studio Display:00008030-001069920AD0802E:8,9
Active Sample Rate: 48kHz
ID 0x75 Studio Display Speakers Manufacturer:Apple Inc.
Model UID:Studio Display Audio Control:05AC:1114 UID:AppleUSBAudioEngine:Apple Inc.:Studio Display:00008030-001069920AD0802E:8,9
Multichannel: 8 channels
Channel bitmap: Ox3f, layout:
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Channel 6 unused
Channel 7 unused
Number of channels: 8
Simple stereo device: No
Number of active channels: 8, in 1 stream(s)
Channel #6 :Stream 0 channel 6
Channel #7 :Stream 0 channel 7
Stream ID 0x76 8 channels starting at 1
8 virtual formats:
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 96kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 88.2kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 44.1kHz
8 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 96kHz
8 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 88.2kHz
8 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 48kHz
8 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 44.1kHz
8 physical formats
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 96kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 88.2kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 48kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 44.1kHz
Local devices found : 4
Device #0: ID 0x75 Studio Display Speakers Manufacturer: Apple Inc. Model UID: Studio Display Audio Control:05AC:1114 UID: AppleUSBAudioEngine:Apple Inc.:Studio Display:00008030-001069920AD0802E:8,9
Device #1: ID 0x63 Altoparlanti MacBook Air Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
Device #2: ID 0x36 BoomAudio Manufacturer: Global Delight Technologies Pvt. Ltd. Model UID: GDAudioDevice_ModelUID UID: GDAudioDevice_UID
Device #3: ID 0x41 Screenflick Loopback Manufacturer: Araelium Group Model UID: com.araeliumgroup.screenflick.loopback UID: com.araeliumgroup.screenflick.loopback
