Audirvāna Studio 2.11.4 linux
新版本无法使用网络共享文件smb 只能添加本地的音乐 请问我该如何操作
Hi @qxj ,
You should be able to acess files using SMB, did you get some form of error when you had this behavior?
我现在把共享的文件smb到核心机了 然后通过app添加本地文件了 之前的版本是本地里面有按键可以直接添加smb的链接的 现在没有了 现在只有添加本地一个选项了
ok 等我有空我给您发过来
Audirvana Studio 2.11.4
Running on Intel(R) Client Systems NUC11PAHi7
Linux 6.10.2-rt14-arch1-5-rt x86_64 x86_64 with 15.3GB physical RAM
Connected account of : qu xinjie
LOADING/DECODING:
Max audio buffer size: 7820MB
Internal EQ: OFF
AUTO: /mnt/music
Sync folders at startup: YES
Sort and display order: en
Library database path: /home/audirvana/.local/share/audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 0
Listening on on port 40327
TIDAL: Connected as PREMIUM
Font size: regular
Language: 中文
我的音乐
无线电收发器
播客
流媒体
本地
Startup view: 我的音乐:专辑
Number of paired remotes: 2
Last audio device error: 选择音频设备错误:Cannot open PCM device
Max. memory for audio buffers: 7820MB
Local Audio Engine: Linux ALSA library 1.2.5.1
Advanced Linux Sound Architecture Driver Version k6.10.2-rt14-arch1-5-rt.
啦啦啦
Model UID:啦啦啦
UID:啦啦啦:Singxer USB Audio 2.0 G2
Active Sample Rate: 11289.6kHz
Selected device:啦啦啦
Manufacturer:
Model name: 啦啦啦
Model UID: 啦啦啦
UID: 啦啦啦:Singxer USB Audio 2.0 G2
0 available sample rates up to 0Hz
Simple stereo device: No
0 output streams:
Device #0: 啦啦啦
Manufacturer:
Model UID: 啦啦啦
Model name: 啦啦啦
eth0
Can you go into the Audirvāna settings and in the My Account section? You will see a ‘Start Log Session’ button; click on it and restart Audirvāna. After doing this, click 'Stop Log Session’ and send me the audirvana_studio.log file you can find by clicking the 'Open Log Folder’ button.
http://euphony.local.:35941/settings/debuglogs?token=d3a3c69b8f843194
I need the content available at this URL. It’s a local network URL, so I’m unable to access it.
