As of today (I think) the version of Audirvana Studio 2.8.2 on my Mac Studio (Sonoma 14.5) has decided to no longer close. In order to do this I have to force the closure in a completely unusual and brutal way!!
Audirvana Studio 2.8.2 (20802)
macOS Version 14.5 (Build 23F79) with 64GB physical RAM
Connected account of : ---------------
Effects plugins ACTIVE in realtime mode with legacy macOS API
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
Bandwidth at 0dB = 99.5%
Phase = 66%
Sync list: 5 folders
AUTO: /Volumes/Musica_Hi_Res/Musica_Blues
AUTO: /Volumes/Musica_Hi_Res/Musica_Classica
AUTO: /Volumes/Musica_Hi_Res/Musica_Disco
AUTO: /Volumes/Musica_Hi_Res/Musica_Jazz
AUTO: /Volumes/Musica_Hi_Res/Musica_Pop, Rock, Leggera
Library database path: /Users/---------------/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Fingerprinting track 9968/10002 : /Volumes/Musica_Hi_Res/Musica_Jazz/Various Artists/VA - 5 Tracks In DSD 1024 (SACD)(2021)(1 - 45,12)/2_Winterreise_D_911_Fruhlingstraum_from_‘Winterreise’.dsf
Listening on 127.0.0.1 on port 49623
Font size: regular
Streaming
My Music
Radios
Podcasts
Use Apple Remote: yes
Number of paired remotes: 2
Screen saver disabled: yes
Max. memory for audio buffers: 8484MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Apple Inc. Studio Display Speakers
Model UID:Studio Display Audio Control:05AC:1114
UID:AppleUSBAudioEngine:Apple Inc.:Studio Display:00008030-001A4C48112A802E:8,9
Active Sample Rate: 96kHz
Selected device:Studio Display Speakers
Model name: Apple Inc. Studio Display Speakers
Model UID: Studio Display Audio Control:05AC:1114
UID: AppleUSBAudioEngine:Apple Inc.:Studio Display:00008030-001A4C48112A802E:8,9
USB Vendor ID: 0x05ac
USB Product ID: 0x1114
ID 0x53
Unhandled (PCM conversion) with boost gain of 2dB
Multichannel: 8 channels
Channel bitmap: Ox3f, layout:
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Channel 6 unused
Channel 7 unused
Number of channels: 8
Simple stereo device: No
Number of active channels: 8, in 1 stream(s)
Channel #6 :Stream 0 channel 6
Channel #7 :Stream 0 channel 7
Stream ID 0x54 8 channels starting at 1
8 virtual formats:
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 96kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 88.2kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 44.1kHz
8 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 96kHz
8 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 88.2kHz
8 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 48kHz
8 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 44.1kHz
8 physical formats
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 96kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 88.2kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 48kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 44.1kHz
Device #0: ID 0x53 Studio Display Speakers
Device #1: ID 0x48 Altoparlanti Mac Studio
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. Altoparlanti Mac Studio
UPnP devices found : 1
Device #0: ID 0x0 : MS120
UID: uuid:b504735e-4129-4507-be5e-30325a177bda
Location: http://192.168.178.22:49349/b504735e-4129-4507-be5e-30325a177bda.xml
Manufacturer: ATOLL Electronique
Model name: MS120
Luckily I managed to solve it myself, from Time Machine I fished out the database file from a few days ago, replaced it and everything started working again;-)
Everything is fine!!
