My Time Machine Backup is set to manually (beeing startet by the app TimeMachine Editor). When I disable Time Machine in Audirvana Studio it is always turned to automatic hourly when I quit Audirvana. So I decided not to disable Time Machine in Audirvana Studio any longer. But I think this is a behviour which should be fixed by Damien.
In the meantime, you can disable Time Machine option in Sysoptimizer settings in Audirvāna as it is basically made to avoid aromatic backup of TimeMachine
There may be something that changed in Ventura and we need to take a look at it.
