see title. But, according to my account page, my Studio subscription should be valid unti 17th of May. What is wrong ?
no, it is the first time. I was trying to startup Studio once again because Audirvana remote (Plus version) on my Ipad would not connect to Origin.
Ok, if you get this error again, please come back to me and I will do further investigations on the subject.
Are you using the same account to connect to AudirvÄna Studio and AudirvÄna Origin?
Yes, I do.
Ok, do you have this behavior on a Windows or Mac device?
Windows (10)
Can you disconnect and then reconnect your account? To do this you need to go to AudirvÄna Origin settings, My Account section.
OK, I did the disconnect/connect action. I can now log into Studio as well.
