Hi Damien, I like very much the new Audirvana Studio (AS). Good job! I have one major issue. Audirvana studio is somehow keeping the exclusive audio access to AVR via UPNP/DLNA all the time.
When I start AS (no audio stream, just start the application) it immediately wakes up the receiver from standby mode and while AS is running (even if there is no music stream) I cannot change the input on receiver. If I switch to f.e. “TV Output”, after a few seconds AS takes back the control. Even if the receiver goes to standby after a few seconds AS wakes it up.
- I’m running AS on mac mini Big Sur 11.3.1 (I tried also on Windows 10. It is the same)
- Receiver Marantz SR6009 - I can provide also the DLNA description.xml
- Bellow you can find the Debug info. Situation when there is no music stream to receiver
Any help very appreciated. Thank you. Kind Regards, Peter
Audirvana Mac Version 1.0.0 (10000)
macOS 11.3.1 with 8192MB RAM
Connected account:
Per track: OFF
Bandwidth at 0dB = 99.5%
Phase = 66%
Max allowed volume: 98.7879
Sync list: 0 folders
Library database path: /Users/audirvana/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 51986
Qobuz: Connected as
Preferred device: MARANTZ MARANTZ SR6009 Model UID:Marantz Marantz SR6009 UID:uuid:5f9ec1b3-ff59-19bb-8530-000678251946
UPnP device at http://192.168.0.96:8080/description.xml
ID 0x0 Family Room
Manufacturer: Marantz
Model Name:
Model UID: Marantz Family Room
UID: uuid:5f9ec1b3-ff59-19bb-8530-000678251946
8 available sample rates up to 5644800Hz
5644800
Volume control: No
DSD capability: Raw DSD (MSB)
http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL
http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO
http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO_320
http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO
http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO_320
http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS
http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM
http-wavetunes::audio/x-ms-wma:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/x-m4a:
http-get::audio/x-mp4:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::image/jpeg:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
16 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz
0 physical formats
NrTracks: 1
MediaDuration: 0:00:00
CurrentURI: http://192.168.0.93:49153/audirvana/audioTest.pcm
CurrentURIMetadata:
dc:titletestTitle</dc:title>
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
<?xml version="1.0"?>1
0
SetAVTransportURI
InstanceID
in
A_ARG_TYPE_InstanceID
CurrentURI
in
AVTransportURI
CurrentURIMetaData
in
AVTransportURIMetaData
SetNextAVTransportURI
InstanceID
in
NextURI
in
NextAVTransportURI
NextURIMetaData
in
NextAVTransportURIMetaData
GetMediaInfo
InstanceID
in
NrTracks
out
NumberOfTracks
MediaDuration
out
CurrentMediaDuration
CurrentURI
out
AVTransportURI
CurrentURIMetaData
out
NextURI
out
NextAVTransportURI
NextURIMetaData
out
PlayMedium
out
PlaybackStorageMedium
RecordMedium
out
RecordStorageMedium
WriteStatus
out
RecordMediumWriteStatus
GetTransportInfo
InstanceID
in
CurrentTransportState
out
TransportState
out
TransportStatus
CurrentSpeed
out
TransportPlaySpeed
GetPositionInfo
InstanceID
in
Track
out
CurrentTrack
TrackDuration
out
CurrentTrackDuration
TrackMetaData
out
CurrentTrackMetaData
TrackURI
out
CurrentTrackURI
RelTime
out
RelativeTimePosition
AbsTime
out
AbsoluteTimePosition
RelCount
out
RelativeCounterPosition
AbsCount
out
AbsoluteCounterPosition
GetDeviceCapabilities
InstanceID
in
PlayMedia
out
PossiblePlaybackStorageMedia
RecMedia
out
PossibleRecordStorageMedia
RecQualityModes
out
PossibleRecordQualityModes
GetTransportSettings
InstanceID
in
PlayMode
out
CurrentPlayMode
RecQualityMode
out
CurrentRecordQualityMode
Stop
InstanceID
in
Play
InstanceID
in
Speed
in
TransportPlaySpeed
Pause
InstanceID
in
Seek
InstanceID
in
Unit
in
A_ARG_TYPE_SeekMode
Target
in
A_ARG_TYPE_SeekTarget
Next
InstanceID
in
Previous
InstanceID
in
SetPlayMode
InstanceID
in
NewPlayMode
in
CurrentPlayMode
GetCurrentTransportActions
InstanceID
in
Actions
out
X_DLNA_GetBytePositionInfo
InstanceID
in
TrackSize
out
X_DLNA_CurrentTrackSize
RelByte
out
X_DLNA_RelativeBytePosition
AbsByte
out
X_DLNA_AbsoluteBytePosition
LastChange
string
TransportState
string
STOPPED
PLAYING
PAUSED_PLAYBACK
TRANSITIONING
NO_MEDIA_PRESENT
TransportStatus
string
OK
ERROR_OCCURRED
string
RecordStorageMedium
string
NOT_IMPLEMENTED
string
string
CurrentPlayMode
string
NORMAL
NORMAL
SHUFFLE
REPEAT_ONE
REPEAT_ALL
TransportPlaySpeed
string
1
string
NOT_IMPLEMENTED
string
NOT_IMPLEMENTED
string
NumberOfTracks
ui4
0
1
CurrentTrack
ui4
0
1
1
string
string
string
CurrentTrackURI
string
AVTransportURI
string
string
NextAVTransportURI
string
string
string
string
i4
i4
string
A_ARG_TYPE_SeekMode
string
TRACK_NR
REL_TIME
string
ui4
string
string
string
0
<dlna:X_DLNADOC xmlns:dlna=“urn:schemas-dlna-org:device-1-0”>DMR-1.50</dlna:X_DLNADOC>
pnpx:X_compatibleIdMS_DigitalMediaDeviceClass_DMR_V001
</pnpx:X_compatibleId>
pnpx:X_deviceCategoryMediaDevices
</pnpx:X_deviceCategory>
pnpx:X_hardwareIdVEN_0126&DEV_0050&REV_01
</pnpx:X_hardwareId>
df:X_deviceCategoryMultimedia.DMR
</df:X_deviceCategory>
Family Room
Marantz
AV SURROUND RECEIVER
*SR6009
6009
000678251946
123810928305
image/jpeg
48
48
24
/BCO_device_sm_icon.jpg
image/jpeg
120
120
24
/BCO_device_lrg_icon.jpg
image/png
48
48
24
/BCO_device_sm_icon.png
image/png
120
120
24
/BCO_device_lrg_icon.png
/RenderingControl/desc.xml
/RenderingControl/ctrl
/RenderingControl/evt
/ConnectionManager/desc.xml
/ConnectionManager/ctrl
/ConnectionManager/evt
/AVTransport/desc.xml
/AVTransport/ctrl
/AVTransport/evt
UPnP devices found : 1
Device #0: ID 0x0 Family Room UID: uuid:5f9ec1b3-ff59-19bb-8530-000678251946 Location: http://192.168.0.96:8080/description.xml
Max. memory for audio buffers: 256MB
Device #0: ID 0x2c Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:108 UID: AppleHDAEngineOutput:1B,0,1,2:0 Model Name: Apple Inc. Built-in Output
Device #1: ID 0x3b HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:108 UID: AppleHDAEngineOutputDP:3,0,1,1:0:{4935-0030-01010101} Model Name: Apple Inc. HDMI
