Audirvana Studio installed on Mac Mini 2010 with High Sierra (500 GBytes SSD and 16 Gbytes) works fine on Local Music, Qobuz HD streaming and mp3 radios but not for Radios France radios like France Musique, I have this issue (in french) :
I don’t know if that may help you, but maybe you should check what is the format of the stream. There are users who discovered that they can play only mp3 radio streams and cannot play AAC or FLAC streams.
Hi Christophe!
I have searched for that radio station “France Musique” and tried the aac stream. I got an error message about “integer”. I went to Audio settings, tried to change from Kernel mode to ASIO.
It caused a audio driver crash in my Windows system (the sound icon changed to a red cross). I then rebooted the computer. I opened AS again and went to the Audio settings and changed to ASIO. Tried the same aac radio stream and it worked. Went back to Kernel mode and it worked too (?!) So i guess radio streams work… most of the time. If you get one of those “integer” errors, try rebooting the computer and it should work.
I guess the software is still in beta phase…
HI Doudou!
I will try to replicate the same error ("some message about “integer”) and see what exactly i did to “solve” the issue.
I will post my findings.
Sorry to say but i have no experience working with macOS.
