I join the Audirvana community after many years with Roon, the sound is better with Audirvana only I would need your feedback for the right Audirvana setting
I use 1 Pc of Control under Windows 11 Pro and Audirvana Studio
AMD Ryzen
16 GB DDR4
JCAT NET CARD XE Network Card
this one is connected in USB to a Box connected itself to the fiber
the second Pc is under Linux Gentooplayer/HQPE for DSD 512 convolution
AMD Ryzen
32GB DDR4 Low Latency CAS 14
JCAT USB XE Board
the assembly is connected to 7 Linear power supplies
the signal is sent in USB to a Holo Sprin 3 level 2 DAC
here for the description, I want to know the main basic settings because I dry a little
First of all for the parameterizations of the DAC input, I indicated several options by a red arrow because I do not sias lesuqlles to use?
Do not use RAW PCM??
Gpaless reading mode??
Fix for parreils with Untimely stops?
Autodectection of DAC MQA??
I use TIDAL Master Family
-DAC not specified as MQA ( Holo Spring 3 Level 2 )
What option should I take
- not MQA?
- Render MQA?
-MQA decoder?
The other specific UPnP parameters will be used in this case, if I’ve understood correctly.
Control Pc1 Windows 11 /Audirvana Studio Ethernet link to Pc 2 Gentooplayer/HQPE Ethernet link to Reference Diretta DST 00 to I2S link for DAC Holo Spring Level 2
You could turn everything off. If it works well, you are ready to listen to music. If there are specific problems that one of the settings matches, you can try that.
There is a ‘plays with Audirvana’ list. Here are validated settings from various applications. Yours is not (yet) among them. You can request a list from @Antoine to fill in, other users can then adopt these settings.
