Hi
Newbie on Audirvana Studio. I am liking the sound quality streaming to my Hegel compared to Airplay.Even though Airplay is lossless, somehow Audirvana is able to extract better info for files over iTunes+BitPerfect.
My main issue is Audirvana Studio abruptly stops playing a song. Its not random, its always at the same spot for a particular track. Its happening only for few of my tracks. The same mp3 file plays well on Apple Music.
Second is when a song is playing, when I fast forward by moving the slider, it restarts the song.
Pls help…
Audirvana Studio 1.14.0 (11400)
macOS Version 12.6 (Build 21G115) with 8GB physical RAM
Connected account of :
AUTO: /Volumes/Public/Music/Tamil/QFR
Library database path: /Users/vsubrama/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 53261
Preferred device: HEGEL HEGEL Model UID:Hegel H120 UID:uuid:1a910c04-1dd2-11b2-86ab-bfb10a2102dd
UPnP device at http://192.168.68.112:38400/description.xml
ID 0x0 Hegel
Manufacturer: Hegel
Model Name: H120
Model UID: Hegel H120
UID: uuid:1a910c04-1dd2-11b2-86ab-bfb10a2102dd
Volume control: No
Avoid RAW PCM streams: No
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::application/ogg:
DLNA 1.5: Yes
Gapless playback: No
Missing events workaround: No
Can play native DSD: No
Volume Control: scalar
14 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz
0 physical formats
NrTracks: 1
MediaDuration: 00:04:33
CurrentURI: http://192.168.68.114:49153/audirvana/audioTest.pcm
CurrentURIMetadata:
dc:titletestTitle</dc:title>
nextURI:
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions TransportState string STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED PlaybackStorageMedium string UNKNOWN CD-DA DVD-VIDEO HDD NETWORK NONE RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string UNKNOWN CD-DA DVD-VIDEO HDD NETWORK PossibleRecordStorageMedia string NOT_IMPLEMENTED CurrentPlayMode string NORMAL SHUFFLE REPEAT_ONE REPEAT_TRACK REPEAT_ALL NORMAL TransportPlaySpeed string 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NOT_IMPLEMENTED NumberOfTracks ui4 0 1 CurrentTrack ui4 0 1 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string LastChange string A_ARG_TYPE_SeekMode string ABS_COUNT TRACK_NR REL_TIME A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4Current device RootDevice description:
<?xml version="1.0"?> 1 0 DMR-1.50 QPlay:2 urn:schemas-upnp-org:device:MediaRenderer:1 Hegel Hegel http://www.hegel.com H120 H120 1.0 http://www.hegel.com uuid:1a910c04-1dd2-11b2-86ab-bfb10a2102dd http://192.168.68.112 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl.xml /RenderingControl /RenderingControl/eventSub urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport.xml /AVTransport /AVTransport/eventSub urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager.xml /ConnectionManager /ConnectionManager/eventSub urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /QPlay.xml /QPlay /QPlay/eventSub http://192.168.68.112:38400UPnP devices found : 6
Device #0: ID 0x0 HomePod UID: uuid:c4f49284-1db6-134b-0080-0005cd88b467 Location: http://192.168.68.106:60006/upnp/desc/aios_device/aios_device.xml
Device #1: ID 0x0 Hegel UID: uuid:1a910c04-1dd2-11b2-86ab-bfb10a2102dd Location: http://192.168.68.112:38400/description.xml
Device #2: ID 0x0 HomePod UID: uuid:58f4febd-0d9f-1b13-0080-0005cd88b467 Location: http://192.168.68.106:60006/upnp/desc/aios_device/aios_device.xml
Device #3: ID 0x0 HomePod UID: uuid:333c48f4-8dc7-1ea8-0080-0005cd88b467 Location: http://192.168.68.106:60006/upnp/desc/aios_device/aios_device.xml
Device #4: ID 0x0 HomePod UID: uuid:a89167fa-5f12-9581-376a-f785444aa073 Location: http://192.168.68.106:60006/upnp/desc/aios_device/aios_device.xml
Device #5: ID 0x0 HomePod UID: uuid:28356f62-9bee-9217-20de-6ffa43672ea4 Location: http://192.168.68.106:60006/upnp/desc/aios_device/aios_device.xml
Max. memory for audio buffers: 5162MB
Device #0: ID 0x32 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:123 UID: AppleHDAEngineOutput:1B,0,1,1:0 Model Name: Apple Inc. Built-in Output
