I’m launching a survey to get a better idea of Audirvana Studio’s success. You just have to copy the lines and add 1 to the lines that concern you. Thanks for taking the time to answer, it’s free
I tried AS : 0
I stay on A 3.5 : 1
I switch to AS : 0
I switch to another alternative : 0
I switched to AS but I also use 3.5 on another system.
So for you it’s;
I tried AS : 1
I stay on A 3.5 : 2
I switch to AS : 1
That would be having both 3.5 and AS on one computer twice. Since I own both a MacBook Air and a Windows laptop. Who both have each version.
You can just create a poll, you know…
Welt
June 17, 2021, 11:03am
6
Je passe à AS: 0
Je reste sur 3,5: 1
Je passe en AS: 0
Yohmi
June 17, 2021, 11:11am
7
Indeed
To create a poll, just click on the gear on the top right
Isn’t it more convenient ?
It sure isn’t (I mean, it is)
It sure is (I mean, it isn’t)
Obi Wan Kenobi
I tried AS : 1
I stay on A 3.5 : 1
I switch to AS : 0
Ok, with your help I’m launching a new survey to get a better idea of Audirvana Studio’s success. You can select a maximum of two choices.
I tried AS
I stay on A 3.5
I switch to AS
