Audirvana Studio 1.7.0 (10700)
macOS 11.0 with 32GB physical RAM
AUTO: /Volumes/LaCie 2TB/Musik
Library database path: /Users/alexanderkoll/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49414
Built-in Output
Model UID:
UID:
Active Sample Rate: 48kHz
ID 0x2d USB-C to 3.5mm Headphone Jack Adapter
Manufacturer: Apple, Inc.
Model Name: Apple, Inc. USB-C to 3.5mm Headphone Jack Adapter
Model UID: USB-C to 3.5mm Headphone Jack Adapter:05AC:110A
UID: AppleUSBAudioEngine:Apple, Inc.:USB-C to 3.5mm Headphone Jack Adapter:DWH936501CTL1MQAT:1
2 available sample rates up to 48000Hz
Stream ID 0x2e 2 channels starting at 1
6 virtual formats:
8 physical formats
Local devices found : 4
Device #0: ID 0x58 SONY TV Manufacturer: Apple Inc. Model UID: AppleGFXHDA:0 UID: AppleGFXHDAEngineOutputDP:f803:0:{D94D-DC02-01010101} Model Name: Apple Inc. SONY TV
Device #1: ID 0x5c LEN L27i-28 Manufacturer: Apple Inc. Model UID: AppleGFXHDA:0 UID: AppleGFXHDAEngineOutputDP:f803:1:{AE30-65E0-01010101} Model Name: Apple Inc. LEN L27i-28
Device #2: ID 0x2d USB-C to 3.5mm Headphone Jack Adapter Manufacturer: Apple, Inc. Model UID: USB-C to 3.5mm Headphone Jack Adapter:05AC:110A UID: AppleUSBAudioEngine:Apple, Inc.:USB-C to 3.5mm Headphone Jack Adapter:DWH936501CTL1MQAT:1 Model Name: Apple, Inc. USB-C to 3.5mm Headphone Jack Adapter
Device #3: ID 0x52 Mac mini Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. Mac mini Speakers
UPnP devices found : 1
Device #0: ID 0x0 XBOX UID: uuid:a52f623d-2447-47e1-a2a7-283b5463892a Location: http://192.168.0.101:2869/upnphost/udhisapi.dll?content=uuid:a52f623d-2447-47e1-a2a7-283b5463892a
